| » GE Refrigerator Temperature control issue |
Model Number: GSS25KGTBWW Brand: GE Age: 1 - 5 years
I have GE side by side refrigerator less than 5 year old and having temperature control issue. Model #: GSS25KGTBWW, serial number: LL 423643. Problem: The temperature is too low. I shut it down and turned it on back after 24 hours. Problem before I shut it down, the temperature in refrigerator is much lower than we set, so vegetables were freeze up. Problem after I turned it on back, the temperature in freezer is much lower than we set, for example, we set it at 0 F, the actual is -8 F. Please advise what I should do, how to start troubleshoot or part to replace. Read more: GE Refrigerator Temperature control issue http://forum.appliancepartspros.com Ads By Google Related Models |
You can check your thermistor ohm readings with a meter if you have one. Typical fresh food and freezer thermistor values can be measured right at the motherboard in the back. Go to sticky above "GE refrigerator (GS & PS models).." for info on this. You will probably find one or two way off the typical values shown in this sticky.
__________________
| Display Modes | |
| GE Refrigerator Temperature control issue | mcistaro | Refrigerator & Freezer Repair | 0 | 12-04-2010 05:52 PM |
| Electronic Control Panel or Touch Pad Control Issue? | maxtout4u@aol.com | Dishwasher Repair | 0 | 10-08-2010 11:33 AM |
| GE Refrigerator Temperature Control Lights do not work | gggibson | Refrigerator & Freezer Repair | 0 | 11-30-2009 05:31 PM |
| Mini GE Refrigerator replacing temperature control | rustbelt | Refrigerator & Freezer Repair | 1 | 08-07-2009 09:19 AM |
| Oven Temperature issue | jojo12 | Oven Repair (including Ranges and Cooktops) | 1 | 05-16-2008 01:24 PM |
