Discuss
Amana not cold on top
 in
Refrigerator & Freezer Repair
My Amana suddenly decided to keep stuff cold in the freezer but not on top in the fridge (freezer is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana not cold on top
  #1 (permalink)
Old 10-07-2007, 03:14 PM
Junior Member
Gopherguy is on a distinguished road
Default Amana not cold on top
Model Number: BG21VW   Brand: Amana   Age: 5 - 10 years
My Amana suddenly decided to keep stuff cold in the freezer but not on top in the fridge (freezer is below the fridge). I took it apart and cleaned out a ton of dust/dirt from the bottom coils. Took the panel off inside the freezer and the coils behind the panel are completely iced and plugged. Is the likley culpret the defrost timer, the thermostat, something else? Thanks.
Ads By Google
Related Models
Amana BG21VW Ref - Bottom Mounts
Whirlpool BGC430WB0
Maytag BGFIM18E5 Undercounter Built in Ice Maker
Whirlpool BGP430WB0
Whirlpool BGS470WB0
Amana BH20S5L Ref - Bottom Mounts
Amana BH20S5W Ref - Bottom Mounts
Amana BH20TL Ref - Bottom Mounts
Amana BH20TW Ref - Bottom Mounts
Whirlpool BHAC0500BS0
Whirlpool BHAC0500BS1
Whirlpool BHAC0500FS0
Whirlpool BHAC0500FS1
Whirlpool BHAC0500XS0
Whirlpool BHAC0500XS1
Whirlpool BHAC0500XS2
Whirlpool BHAC0500XS4
Whirlpool BHAC0500XS5
Whirlpool BHAC0600BS0
Whirlpool BHAC0600XS1
Whirlpool BHAC0700BS0
Whirlpool BHAC0700FS0
Whirlpool BHAC0700XS0
Whirlpool BHAC0830AS0
Whirlpool BHAC0830AS1
Whirlpool BHAC0830XS0
Whirlpool BHAC1000BS0
Whirlpool BHAC1000FS0
Whirlpool BHAC1000XS0
Whirlpool BHAC1000XS1
Whirlpool BHAC1000XS2
Whirlpool BHAC1000XS3
Whirlpool BHAC1200BS0
Whirlpool BHAC1200FS0
Whirlpool BHAC1200XS0
Whirlpool BHAC1200XS1
Whirlpool BHAC1230AS0
Whirlpool BHAC1230AS1
Whirlpool BHAC1230XS0
Whirlpool BHAC1250XS0
Whirlpool BHAC1400BS0
Whirlpool BHAC1400BS1
Whirlpool BHAC1400FS0
Whirlpool BHAC1400XS0
Whirlpool BHAC1800BS0
Whirlpool BHAC1800BS1
Whirlpool BHAC1800BS2
Whirlpool BHAC1800FS0
Whirlpool BHAC1800XS0
Whirlpool BHAC1830AS0
Whirlpool BHAC1830AS1
Whirlpool BHAC1830XS0
Whirlpool BHAC2400BS0
Whirlpool BHAC2400BS2
Whirlpool BHAC2400FS0
Whirlpool BHAC2400XS0
Whirlpool BHAC2530ES0
Whirlpool BHDH2500AS0
Whirlpool BHDH2500AS1
Whirlpool BHDH2500AS2
Whirlpool BHDH2500FS0
Whirlpool BHDH4000AS0
Whirlpool BHDH4000AS2
Whirlpool BHDH4000AS3
Whirlpool BHDH4000FS0
Whirlpool BHDH5000BS1
Whirlpool BHDH5000BS2
Amana BHK2 Misc / Accessory
Amana BHKT1 Misc / Accessory
Amana BHKT2 Misc / Accessory
Amana BI8 Misc / Accessory
Maytag BICNS24D9  Ref - SXS/I&W
Maytag BICNS24D9A  Ref - SXS/I&W
Maytag BICNS24D9H  Ref - SXS/I&W
Maytag BICNS24F9  Ref - SXS/I&W
Maytag BICNS24F9A  Ref - SXS/I&W
Maytag BICNS24F9H  Ref - SXS/I&W
Maytag BICNT22F9  Ref - Top Mount/ I&W
Maytag BICNT22F9A  Ref - Top Mount/ I&W
Maytag BICNT22F9H  Ref - Top Mount/ I&W
Maytag BICT18F9L  Ref - Top Mount/ I&W
Maytag BICT18F9LA  Ref - Top Mount/ I&W
Maytag BICT18F9LH  Ref - Top Mount/ I&W
Amana BIF Freezer - Vertical
Amana BIFA Freezer - Vertical
Amana BIFL Freezer - Vertical
Amana BIFLA Freezer - Vertical
Amana BIR Freezer - Vertical
Amana BIRA Freezer - Vertical
Amana BIRL Freezer - Vertical
Amana BIRLA Freezer - Vertical
General Electric BIS42AJB Refrigerator
General Electric BIS42AJC Refrigerator
General Electric BIS42AJD Refrigerator
General Electric BIS42CKB Refrigerator
General Electric BIS42CKC Refrigerator
General Electric BISB42EKB Refrigerator
General Electric BISB42EKC Refrigerator
General Electric BISB42ELB Refrigerator
General Electric BISB42ELC Refrigerator
General Electric BISB42ELD Refrigerator
General Electric BISB42ELE Refrigerator
General Electric BISW42EKB Refrigerator
General Electric BISW42EKC Refrigerator
General Electric BISW42ELB Refrigerator
General Electric BISW42ELC Refrigerator
General Electric BISW42ELD Refrigerator
General Electric BISW42ELE Refrigerator
General Electric BJLR473ET0WW Electric dryer
General Electric BJLR473EV0WW Electric dryer
General Electric BJLR473GT0WW Gas dryer
General Electric BJLR473GV0WW Gas dryer
Whirlpool BJSSAC0800
Whirlpool BJSSAC1000
  #2 (permalink)
Old 08-21-2008, 12:29 PM
Junior Member
tonimarie is on a distinguished road
Default
I have the same problem. I unplugged overnight and it started working, work for 3-4 days and quit again. hope someone replies cause I would love to know the problem
  #3 (permalink)
Old 08-21-2008, 12:44 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
It's usually one of three things, the defrost timer, defrost thermostat or the element.
Some models have a defrost control (control board)
First for a temp fix unplug the unit, remove the back panel in the freezer use a hair drier to thaw ALL the ice out. Look for your defrost heater see if it looks discolored or if you can see a visible break. Also look for the Def thermostat, a little round thing that has a popup on top and two wires going to it, it the top is popped or it looks chared that's probably your problem. Put it back together and plug it in. It will cool for upto 2 weeks if your lucky(time to get parts in!)
I'll look at the breakdown to see part numbers.
Hope that helps
Nat
  #4 (permalink)
Old 08-21-2008, 12:59 PM
Senior Expert
APP Volunteer
Default
Gopherguy...
Chances are it's not your element due to the type it is.
The Defrost thermostat is part number AP175103
Defrost timer Part AP98191 (since your frig has this type of timer. located on the back near the compressor) Try this first Leave the machine plugged in and turn the little red "knob" a little at a time until your frig kicks off. then wait and listen for popping ice, maybe some sizzling if so then is' defrosting and should kick back on in about 30 minutes. If not then defrost your frig manually as I stated before and we will figure out which part is out.
Nat
toni_ post your model number please
  #5 (permalink)
Old 02-24-2009, 04:23 PM
Junior Member
tlang is on a distinguished road
Default
Had the same problem, Evaporator fan in the rear panel of the inside freezer compartment froze. replaced fan motor and is working fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigeratior/Freezer too cold stevetijeras Refrigerator & Freezer Repair 3 02-23-2010 01:42 PM
Amana freezer won't get cold enough 3handygals Refrigerator & Freezer Repair 1 09-30-2009 03:49 PM
Amana refrigerator not cold dppham Refrigerator & Freezer Repair 0 01-23-2009 08:20 AM
Amana Frige Not Getting Cold elmer29 Refrigerator & Freezer Repair 1 12-03-2008 04:14 PM
Amana SbyS Freezer not cold kdex Refrigerator & Freezer Repair 1 05-22-2008 11:37 AM
