| » Fridge & Freezer not working |
Model Number: TBX14SYSJRWH Brand: GE Age: More than 10 years
Fridge has been leaking water on inside for a while now. Noticed today Fridge not cold, Freezer is cold but not freezing. What could this be??????
If both evaporator and condensing fans running, pull back panel of fridge and verify condensing fan is running and also the compressor. Just feel the compressor for vibration. Also verify condenser coils are warm/hot.
If everything ok, pull the freezer back panel and look for a totally frozen evaporator. If so, locate the defrost timer in the control panel. It will have an access hole to turn the knob. Turn it clockwise till the compressor turns off. Check the defrost heater, it should be hot, if hot, you have a bad defrost timer,if not hot, you probably have a bad defrost thermostat, a round thing clipped to the evaporator coil. Click on your model # to order the parts.
__________________
| Display Modes | |
| Fridge & Freezer not working | tgammons | Refrigerator & Freezer Repair | 0 | 10-07-2007 01:25 PM |
| Fridge / Freezer stopped working | cardinco | Refrigerator & Freezer Repair | 2 | 10-05-2007 07:06 PM |
| Freezer not freezing/ fridge okay | csfinlay | Refrigerator & Freezer Repair | 1 | 09-28-2007 03:36 AM |
| Fridge not working | jamie7 | Refrigerator & Freezer Repair | 0 | 08-12-2007 09:08 AM |
| Hot Frame between Fridge and Freezer | mshilko | Refrigerator & Freezer Repair | 3 | 07-20-2007 01:57 PM |
