I have GE side by side refrigerator less than 5 year old and having temperature control issue. Model #: GSS25KGTBWW, serial number: LL 423643. [FONT="] [/FONT] Problem: The temperature is too low. I shut it down and turned it on back after 24 hours. Problem before I shut it down, the temperature in refrigerator is much lower than we set, so vegetables were freeze up. Problem after I turned it on back, the temperature in freezer is much lower than we set, for example, we set it at 0 F, the actual is -8 F. Please advise what I should do, how to start troubleshoot or part to replace.
Thanks in advance. :)
