I have a fridgadare freezer that was cooling to 5 below zero when set to 7 on the temp control but on any lower number it would thaw. I replaced the temp control with one I purchased from you, now it cools to 5 below zero at any setting, it will turn off in the off position but runs continously at any other setting.
any suggestions Bob Immel
