tfreeze
#1 Posted : Friday, December 3, 2010 7:02:50 PM(UTC)
tfreeze
My freezer is icing up and I'm having trouble locating the defrost timer to check it. I understand that is the first step from reading other threads. Any help on locating this part on my model would be appreciated. Thanks!
kayakcrzy
#2 Posted : Saturday, December 4, 2010 3:38:57 AM(UTC)
kayakcrzy
Your is electronic. Your problem is most likely the defrost thermostat. If you take your icemaker out, and remove the all the ice from the coil, with hot water, or a blow dryer, the defrost thermostat is on the top right side of the coil. It is about the size of a quarter, and has 2 wires coming out of it. That seems to be ther only problem with that refrigerator. Sometimes you can look at the top of the defrost thermostat, and you can see the top is pushing out. If you defrost the coil, it will cool fine for about 4 to 5 days, till you get your part. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
