| » Frigidaire PLRU1778ESO not cooling |
Model Number: PLRU1778ESO Brand: Frigidaire Age: 1 - 5 years
My refrigirator has stop cooling. This is a stand alone unit. The freezer is a separate stand alone unit. Everything appears to be running. Both fans running, compressor running. I took the inside panel out and there was a little frost on the Heat exchange that comes in from the bottom left corner and runs to the evaporator. The evaporator had no frost on it. Any help with what is the problem would be appreciated. It is about 20 months old.
Replacement parts for PLRU1778ESO models | AppliancePartsPros.com Sounds like you are low on freon or there is a plug in the sealed system. Note : The test of the frost on the evaporator coils must be done after the unit has run several hours without a defrost cycle. Here is a good link http://www.applianceaid.com/refrigerator.html Check out the example pictures half way down the page of #20. Here is the operators manual http://manuals.frigidaire.com/prodin...97055300en.pdf Check out the warranty. Since the unit is only 20 months old it should be covered under warranty. Usually when units are past warranty it makes more sense to replace the unit as you need a pro and this repair is expensive Also there is no use refilling the unit with freon unless the leak is located and repaired.
__________________
| Display Modes | |
| 1.5 YEAR OLD frigidaire not cooling anymore!!!!! PLEASE HELP! | sssb2000 | Refrigerator & Freezer Repair | 2 | 07-01-2010 05:16 AM |
| Frigidaire not cooling | Judwyn | Refrigerator & Freezer Repair | 1 | 03-12-2010 02:03 AM |
| Frigidaire S by S not cooling/freezing | tahoe437 | Refrigerator & Freezer Repair | 1 | 03-14-2009 08:36 PM |
| Frigidaire Cooling Fan Question | Bee46 | Refrigerator & Freezer Repair | 13 | 06-22-2008 01:31 PM |
| Frigidaire Freezer not cooling | Ken TN | Refrigerator & Freezer Repair | 1 | 04-28-2008 03:47 AM |
