OK appliance guys....I need your help! ANOTHER problem with GE product. Profile side by side not making ice and water slowly dripping from water dispenser. Will dispense water if button is pushed (we stopped using it years ago for fear it would leak again). Ice maker seams to be "cycling" cause is burned my finger when I touched the tray. Replaced the blue pump at bottom rear one year ago. Just the front pump not the entire front and back pump(s). Not sure what the problem is because I see only one inlet to the pump and the two hoses coming out the back could they be connected inside the frig??? Please help
After looking around the web site for possible parts. Since there's no water in the ice maker could it be the other "water valve" ie the back one?? Thanks Guys for any help...:cool:
