I have a kitchenaid side-by-side with an in-door ice dispenser which is not working. The water dispenser and light work. The ice dispenser door also operates. The ice dispenser motor does not even attempt to operate. The wiring harness comes in from the top hinge, and does not appear to be damaged. Is there some diagnostic I can do to check the ice dispenser motor or control panel?
You have to check the ice dispenser motor first. The instructions are attached to the reply. - The motor Part number: AP3776020
