| » Freezer frosted up after I turned power off |
Model Number: 10653602201 Brand: Kenmore Age: 5 - 10 years
The refrigerator side of my side by side Kenmore hasn't been cooling. There is ice-build up on the coils of the freezer. I turned the power off to defrost the freezer manually. The ice wasn't completely melted before I went to bed so I d left the door open overnight. This morning there was even more frost on the coils than there was the night before. What would cause freezing after the power is turned off?
You need to locate your defrost timer, probably in the fridge control panel. Just turn the knob till the compressor stops, then remove freezer back panel and look for the defrost heater and verify it is heating, if so, you have a bad defrost timer.
If no defrost, you probably have a bad defrost thermostat. You can click on your model # above to get parts.
__________________
| Display Modes | |
| Ice Maker Dispensing Chute Frosted Up & Jams | Roggy | Refrigerator & Freezer Repair | 9 | 10-15-2008 11:38 AM |
| power surge | tbarner | Refrigerator & Freezer Repair | 1 | 09-17-2007 10:34 AM |
| No Power? | dangdryer | Dryer Repair | 0 | 09-05-2007 05:17 AM |
| Milk and water freezing temp turned down. thermostat? | bidd1 | Refrigerator & Freezer Repair | 1 | 08-11-2007 04:36 PM |
| fan does not rotate when turned on so no cold air comes out just alot of noise | SKEET21 | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 08-03-2007 11:37 AM |
