Golion
#1 Posted : Friday, November 14, 2008 11:32:58 AM(UTC)
Golion
For a year, my freezer makes a loud short rattling noise which I believe is the compressor turning off or on. Like metal clanging. Anyhow it's just louder than it should be.
I was recently gone for 4 days and when I came back, there was a loud buzzing noise that came on. I unplugged it immediately. It seems the door was not closed good either. All the food was thawed and the freezer wasn't producing much cold. It's been unplugged for 2 days and everything cleaned out. Plugged it back in for a few seconds and there was a buzzing noise.
Has the compressor gone bad? Any tips to get it fixed?
libertyappl
#2 Posted : Friday, November 14, 2008 12:37:46 PM(UTC)
libertyappl
Did you hear any clicking noises? or just buzzing?
Nat
Golion
#3 Posted : Friday, November 14, 2008 12:45:04 PM(UTC)
Golion
I didn't hear any clicking at the time. I unplugged it right away when I first heard the buzzing. Should I plug it back in to see if there is any and how long the buzzing sounds?
libertyappl
#4 Posted : Friday, November 14, 2008 2:54:32 PM(UTC)
libertyappl
Need to know exactly where the buzzing is coming from, the compressor itself or the electrical components.
Nat
Golion
#5 Posted : Friday, November 14, 2008 4:24:18 PM(UTC)
Golion
If I'm not mistaken, the black concave shape in the back/bottom of the freezer is the compressor? If so, yes the buzzing is coming from the compressor. There is no clicking. The buzz lasts for a few seconds.
libertyappl
#6 Posted : Friday, November 14, 2008 5:27:12 PM(UTC)
libertyappl
If it's coming from the compressor it's probably siezed up. Which leaves you with two options go shopping or have a technician repair it.
Nat
Golion
#7 Posted : Friday, November 14, 2008 7:30:24 PM(UTC)
Golion
How much does it usually cost to have it repaired?
Btw, I listened to it again. The buzzing starts every several minutes. There is a clicking noise when the buzzing starts and stops.
libertyappl
#8 Posted : Friday, November 14, 2008 7:46:12 PM(UTC)
libertyappl
The clicking sounds like the relay (electricals) if it's been doing that for a while before you unplugged the unit it probably took out the compressor.
The compressor comes with new electricals. Part # AP3108882 or AP204149(the 1st being the exact part) would work. Depending on what a EPA certified technician would charge in your area would run around $500 for replacement.
With that said I would have a technician verify it's a compressor problem because we can't see and hear what you can.
If you were here we could do it for less because I got a few good buys on compressors and live in a pretty rural area.
Nat
Golion
#9 Posted : Friday, November 14, 2008 8:03:49 PM(UTC)
Golion
Thank you. Now have to find a reliable technician who hopefully could do it for less.
