Freezer not freezing Cold 20 Degrees A little frost was formed on back inside wall (Removal of back inside freezer panel) Ice on a black thing with wires coming out All cleaned off as well as dust on back and under outside of unit Compressor humming away and is warm Unfortunately the icecream is mush.
Here are your parts Replacement parts for FRIGIDAIRE FRS26R4CQ1 Frigidaire/refrigerator | AppliancePartsPros.comI am not sure that I understand your post. The compressor is running? You removed the evaporator cover inside the freezer and checked the evaporator coils? The coils were not heavily iced/frosted over? Was the evaporator fan running? If the compressor is running, the evaporator fan is running and the evaporator coils are not heavily iced/frosted over then: You may be low on freon You may be out of freon The compressor may be toast All of the above require a pro to repair it and it will be expensive. In most cases it is better to put those dollars towards a new unit. Here is a good link http://www.applianceaid.com/refrigerator.htmlTake a look at #20 which seems to fit your symptoms. |
THIS FORUM IS DEAD!!!!!!! |
