The dispenser on my ice maker is not working. The motor that is supposed to drive the dispense auger is running but the auger would not turn. I looked at the drive gear on the bottom of the dispenser & it looked worn so I ordered a new complete ice container. When I installed it the dispenser worked a couple of times the quit again. It seems like the motor drive is not fitting up into the auger drive. Is there an adjustment on the motor or motor drive to raise it up to reach inside the auger drive?
Jim Davidson
