| » Not blowing cold air - suggested next steps |
Model Number: GSS25LSMF BS Brand: GE Age: 5 - 10 years
My side by side has stopped getting cold on both sides. I thought it was the Overload WR08X10025 because it was rattling when I took it out (even though it Ohm tested at 0). Well I replaced it and that was not it.
Condensor fan is working. I don't know if the Evaporator fan is working. The compressor is room tempature and is not making any noise. It does not appear to be working. I am not getting any voltage reading from any combination of the three wires. Should I be able to read an electical current from the Overload and Relay? I did not take it apart to see if the coils were freezing up, but it was unplugged for days prior to putting in the Overload. When I put the Overload in, it never got cold so I assume the its not the defroster. Please provide me some input on what I should check next. Should I do some tests on the motherboard or take it apart from the inside to check the Evaporator fan? Thanks!! Ads By Google Related Models |
Quote:
Ok, I need a motherboard. Should I be concerned about what caused it? What are the recommended next steps? Thanks! Skip |
They have a newly designed board that should be more reliable, when they wave soldered your old board, they didn't get a good solder connection at the relay pins.
__________________
Your a good man...I appreciate your help!
| Display Modes | |
| dryer blowing cold air | charles beal | Dryer Repair | 1 | 07-09-2010 03:47 PM |
| Freezer blowing Cold Air but not Cold enough to freeze | tom bacci | Refrigerator & Freezer Repair | 4 | 04-16-2010 12:23 PM |
| Freezer not cold, air blowing in not cold enough and clicking. | Tapper65 | Refrigerator & Freezer Repair | 1 | 11-19-2009 12:12 PM |
| Freezer not blowing cold air | Ride4lifeCBR | Refrigerator & Freezer Repair | 2 | 03-13-2009 09:49 AM |
| Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough | tvGhouse | Refrigerator & Freezer Repair | 0 | 02-25-2009 02:50 PM |
