Discuss
LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure
 in
Refrigerator & Freezer Repair
This Refrigerator Has A Cam Hinge Or Some Call It A Cam Shaft At The Top Of Both The Left
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure
  #1 (permalink)
Old 11-13-2008, 03:25 AM
Junior Member
ServicePlus is on a distinguished road
Default LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure
Model Number: LRFD25850ST   Brand: -brand-   Age: 1 - 5 years
This Refrigerator Has A Cam Hinge Or Some Call It A Cam Shaft At The Top Of Both The Left And Right Doors. It Looks Like It Is Held In Place Behind The Door Gasket Somehow. I Have The Part But I Am Uncertain How To Get To It Properly Without Damaging The Door. Any Suggestions?
Thanks,
Jimmy C.
Ads By Google
Related Models
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
Maytag LRTD19A Ref - Top Mount
Maytag LRTD21A Ref - Top Mount
Maytag LRTD23A Ref - Top Mount
Maytag LRTS17A Ref - Top Mount
Maytag LRTS19A Ref - Top Mount
Maytag LRTW22A Ref - Top Mount/ I&W
  #2 (permalink)
Old 11-13-2008, 01:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hopefully this Service manual will help you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-13-2008, 01:13 PM
Junior Member
Default
Thanks for the reply. I already had the manual, it just doesn't show the cam at the top of the door or show how to replace it. I'm going to go through the motions of removing the door gasket in hopes that I cam replace the door cam.
  #4 (permalink)
Old 11-13-2008, 01:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good luck and keep us posted.
__________________
  #5 (permalink)
Old 11-13-2008, 01:19 PM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Are you talking about the levers that catch in the strike on top of the cabinet in front? It comes as the whole gasket
__________________
  #6 (permalink)
Old 04-21-2009, 06:45 AM
Junior Member
yu130960 is on a distinguished road
Default Another broken CAM
Sorry about bringing up an old thread but I am in the same situation.
I am receiving conflicting reports from the parts guys who are the only ones with an exploded parts diagram.
My LG model Number is LFC22740ST
The top left cam is broken on the door,
The first LG parts CSR said that it is one assembly with the gasket:
Part Number 4987JJ2003H $129.93 CDN
The second guy said I can get just the CAM
Part Number 4430JJ2005B $8.99 USD
Does anyone with access to the parts scematic give me comfort on what is what, and if so anyone have experience as the OP has requested on how to replace just the cam.
The service manual for my particular fridge would be great as well if anyone has access to it.
Thanks guys.
  #7 (permalink)
Old 04-21-2009, 09:21 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Maybe these diagrams will help. Look at case parts and door parts. LG | Model #LFC22740ST | REFRIGERATOR | ********************************.com
  #8 (permalink)
Old 04-21-2009, 11:43 AM
Junior Member
Default
Thanks for the link.
I imagine the other parts guy was cross-referencing the cam to another model and the parts diagram you attached shows the entire assy. $$$
Is it much of an effort to take out the door gasket? I don't want to take it out and then get stuck sans fridge. Are the gaskets just held in with internal clips? Is there anything that I can break?
Thanks for your help.
  #9 (permalink)
Old 06-06-2009, 09:33 AM
Junior Member
lmallahan is on a distinguished road
Default I too have the same issue with the cams
Can someone tell me how these cams work. The bracket has a small spring but I do not see how the cams react to the spring on the bracket/gasket it is attached to. When I try to manually move the cam it causes the entire bracket to move and shows stress on the bracket. eventually it is going to break. Am I missing something here?
  #10 (permalink)
Old 06-06-2009, 10:13 AM
Hardcore DIY'er
APP Volunteer
Default
Post your model number for your fridge.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag french door ice20 - have new icemaker - how do I install? bmjabber2 Refrigerator & Freezer Repair 7 05-25-2011 07:57 PM
Maytag french door fridge freezer on bottom lshamim Refrigerator & Freezer Repair 6 08-18-2009 08:14 AM
GE French door bottom freezer lights don't work Carloppriori Refrigerator & Freezer Repair 1 06-13-2009 05:31 PM
LG- French Door Bottom Freezer is cold but refrigeration warm ktmguy Refrigerator & Freezer Repair 6 01-16-2009 02:35 PM
Kenmore Freezer Door Bottom Hinge ARNOLDJONES Refrigerator & Freezer Repair 8 07-20-2008 01:21 PM
