Discuss
Help with replacement relay overload for compressor
 in
Refrigerator & Freezer Repair
Please help! Our side by side Kenmore refrigerator quit cooling and we traced the problem to a faulty relay or
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Help with replacement relay overload for compressor
  #1 (permalink)
Old 11-12-2008, 04:54 PM
Junior Member
Taeya is on a distinguished road
Default Help with replacement relay overload for compressor
Model Number: 596.58642891   Brand: Kenmore   Age: 5 - 10 years
Please help! Our side by side Kenmore refrigerator quit cooling and we traced the problem to a faulty relay or overload on the compressor. The fan ran all the time but the compressor would never kick in. It would hum and then click off without starting. Because of some extremely helpful info on this site (thanks!) we were able to test the resistance on the compressor and everything added up - there was a reading of 2, 9 and 11. Also, it was not grounded. So, that was good news. We weren't sure at first because when we took the relay off a few days ago, it did not rattle and was not burned looking. However, a repairman said that it could still be a bad relay. Needless to say, we were relieved when the compressor checked out okay. Yesterday we went to an appliance parts store and the manufacturer parts were not in stock, so the man my husband talked to recommended a combination relay overload (MA-IC13 by MA-Line) that he said is very popular and he sells a lot of. However, when my husband got home and tried to put it on he ran into some problems because the part has 2 lines, but our refrigerator has 3 wires (blue to overload, black that was spliced and connected to overload and also to relay, and white to relay). As he is not an electrician, he just guessed and wired the the white wire and one side of the black wire to the relay overload and wired the other side of the black wire and the blue wire together. Well, after plugging in the fridge, the fan started running, but the compressor never even attempted to kick in. Today, my husband talked to the guy from the part store and he told him to just wire the blue and white wires to the relay overload and cap off the black wires. Well, now the compressor hums and clicks off, but the fan doesn't run at all. Is there some way to get everything wired up properly so it will work again?? Is it even possible to use this part with our particular refrigerator? Even if we can get it working, is this okay to use long term or should this just be a temp fix until we can get the manufacturer parts in? Sorry this is so long, I just wanted to give all the details, so hopefully someone can help us. Thanks so much!!
Related Models
Kenmore 59650002100 REFRIGERATOR
Kenmore 59650003100 REFRIGERATOR
Kenmore 59650004100 REFRIGERATOR
Kenmore 59650009100 REFRIGERATOR
Kenmore 59650012100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650013100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650014100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650019100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650392000 REFRIGERATOR
Kenmore 59650392001 REFRIGERATOR SXS
Kenmore 59650392990 SIDE-BY-SIDE
Kenmore 59650394000 REFRIGERATOR
Kenmore 59650394001 REFRIGERATOR SXS
Kenmore 59650394990 SIDE-BY-SIDE
Kenmore 59650399000 REFRIGERATOR
Kenmore 59650399001 REFRIGERATOR SXS
Kenmore 59650399990 SIDE-BY-SIDE
Kenmore 59650692000 KENMORE SXS REFRIGERATOR
Kenmore 59650692001 REFRIGERATOR SXS
Kenmore 59650694000 KENMORE SXS REFRIGERATOR
Kenmore 59650694001 REFRIGERATOR SXS
Kenmore 59650699000 KENMORE SXS REFRIGERATOR
Kenmore 59650699001 REFRIGERATOR SXS
Kenmore 59651672100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651673100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651674100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651679100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59652672200 KENMORE REFRIGERATION
Kenmore 59652672201 KENMORE REFRIGERATOR
Kenmore 59652672202 KENMORE REFRIGERATION
Kenmore 59652673200 KENMORE REFRIGERATION
Kenmore 59652673201 KENMORE REFRIGERATOR
Kenmore 59652673202 KENMORE REFRIGERATION
Kenmore 59652674200 KENMORE REFRIGERATION
Kenmore 59652674201 KENMORE REFRIGERATOR
Kenmore 59652674202 KENMORE REFRIGERATION
Kenmore 59652679200 KENMORE REFRIGERATION
Kenmore 59652679201 KENMORE REFRIGERATOR
Kenmore 59652679202 KENMORE REFRIGERATION
Kenmore 59653462300 KENMORE REFRIGERATOR
Kenmore 59653462301 KENMORE REFRIGERATOR
Kenmore 59653462302 KENMORE REFRIGERATOR
Kenmore 59653463300 KENMORE REFRIGERATOR
Kenmore 59653463301 KENMORE REFRIGERATOR
Kenmore 59653463302 KENMORE REFRIGERATOR
Kenmore 59653464300 KENMORE REFRIGERATOR
Kenmore 59653464301 KENMORE REFRIGERATOR
Kenmore 59653464302 KENMORE REFRIGERATOR
Kenmore 59653469300 KENMORE REFRIGERATOR
Kenmore 59653469301 KENMORE REFRIGERATOR
Kenmore 59653469302 KENMORE REFRIGERATOR
Kenmore 59655652500 KENMORE REFRIGERATOR
Kenmore 59655653500 KENMORE REFRIGERATOR
Kenmore 59655654500 KENMORE REFRIGERATOR
Kenmore 59655659500 KENMORE REFRIGERATOR
Kenmore 59655662500 KENMORE REFRIGERATOR
Kenmore 59655663500 KENMORE REFRIGERATOR
Kenmore 59655664500 KENMORE REFRIGERATOR
Kenmore 59655669500 KENMORE REFRIGERATOR
Kenmore 59657002600 KENMORE REFRIGERATOR
Kenmore 59657003600 KENMORE REFRIGERATOR
Kenmore 59657006600 KENMORE REFRIGERATOR
Kenmore 59657009600 KENMORE REFRIGERATOR
Kenmore 59657012600 KENMORE REFRIGERATOR
Kenmore 59657013600 KENMORE REFRIGERATOR
Kenmore 59657016600 KENMORE REFRIGERATOR
Kenmore 59657019600 KENMORE REFRIGERATOR
Kenmore 59657043600 KENMORE REFRIGERATOR
Kenmore 59657049600 KENMORE REFRIGERATOR
Kenmore 59657053600 KENMORE REFRIGERATOR
Kenmore 59657059600 KENMORE REFRIGERATOR
Kenmore 59657082790 20" BUILDERS SIDE BY SIDE
Kenmore 59657082791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657085790 20" BUILDERS SIDE BY SIDE
Kenmore 59657085791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657087790 20 BUILDERS SIDE BY SIDE
Kenmore 59657087791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657089790 20" BUILDERS SIDE BY SIDE
Kenmore 59657089791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657542790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657542791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657547790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657547791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657582790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657582791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657585790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657585791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657587790 SIDE BY SIDE REFRIGERATOR
Kenmore 59657587791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658392890 Side-by-Side
Kenmore 59658395890 Side-by-Side
Kenmore 59658397890 Side-by-Side
Kenmore 59658622990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658627990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658632890 Side-by-Side
Kenmore 59658632891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658634000 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658635890 Side-by-Side
Kenmore 59658635891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658637890 Side-by-Side
Kenmore 59658642890 Side-by-Side
Kenmore 59658642891 REFRIGERATOR
Kenmore 59658644000 REFRIGERATOR
Kenmore 59658647890 Side-by-Side
Kenmore 59658692890 Side-by-Side
Kenmore 59658695890 Side-by-Side
Kenmore 59658697890 Side-by-Side
Kenmore 59661102100 REFRIGERATOR
Kenmore 59661102101 REFRIGERATOR
Kenmore 59661103100 REFRIGERATOR
Kenmore 59661103101 REFRIGERATOR
Kenmore 59661104100 REFRIGERATOR
Kenmore 59661104101 REFRIGERATOR
Kenmore 59661109100 REFRIGERATOR
Kenmore 59661109101 REFRIGERATOR
Kenmore 59661142100 REFRIGERATOR
Kenmore 59661142101 REFRIGERATOR
Kenmore 59661144100 REFRIGERATOR
Kenmore 59661144101 REFRIGERATOR
Kenmore 59661152100 REFRIGERATOR
  #2 (permalink)
Old 11-12-2008, 05:14 PM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
What does the relay you bought look like? IF it has a tecumseh compressor in it the relay probably wont help but we can try But I dont know what you are trying to hook up
__________________
  #3 (permalink)
Old 11-12-2008, 05:34 PM
Junior Member
Default
The compressor is a tecumseh...is that bad? I'm attaching a few photos of the relay so you can see for yourself. Do you need any more info from me? Thanks for the quick reply and for your help!!!
  #4 (permalink)
Old 11-12-2008, 06:51 PM
Junior Member
Default
So...I did a little research and found out tecumseh compressors don't have the best name. My question is this though, I tested the compressor with an ohmmeter like icehouse described in this thread (compressor hot, fridge and freezer not cooling) and everything tested okay. No zero readings when checking for shorted compressor, no infinity readings when checking for open windings and no reading when testing for grounds. Could it still be a bad compressor even though all that checked out?
By the way, thanks again for your help. Living out of a mini fridge for nearly a week with 3 small children is less than thrilling, so it will be wonderful to get this figured out!
  #5 (permalink)
Old 11-12-2008, 07:20 PM
Senior Expert
APP Volunteer
Default
it should tell ya on the package but some are wired not to industry standards but if its the kind i'm thinking black goes to common white to start and red to run then bllack wires are to your power source but before you hack the refrigerator wires get an old extension cord and wire it to that one to hot one to common and see if comressor will run with justy that and nothing to frig will come on but comressor if it works that way first then the compressor mightg last a little longer but you are just buying time those compressors were'nt very good and usually failed within 5 years you might have compressor warranty left depending how old it is
__________________
  #6 (permalink)
Old 11-12-2008, 09:10 PM
Junior Member
Default
Well...my husband just wired it straight to an extension cord and the compressor buzzed and then clicked off. Does that mean it's beyond help? Just out of curiosity, why would it have tested okay on the ohmmeter? Thanks so much, I really appreciate all your help.
  #7 (permalink)
Old 11-12-2008, 09:20 PM
Senior Expert
APP Volunteer
Default
The windings check ok but that doesn't alweays mean its good How old is it? Those Trios all had the same issue with compressor.You can replace the compressor for about 500
__________________
  #8 (permalink)
Old 11-13-2008, 03:06 AM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Quote:
The reason it probably failed to start even though the ohmmeter test was good was due to the internal motor locking or freezing up.
If you had a repairman look at it, why didn't he check this out for you as I am sure you paid him.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
  #9 (permalink)
Old 11-13-2008, 04:40 AM
Junior Member
Default
It is about 8 years old. The repairman didn't actually look at it. I called him and after describing the problem to him, he agreed that it was either a bad compressor or bad relay. I asked him if it could still be the relay even though it didn't look or sound fried and he said yes, it could still be bad. He personally doesn't even replace compressors anymore because of the cost involved. Told me it would probably be best to just replace the fridge if it did turn out to be the compressor... As we're on a bit of a tight budget, we tried to figure it out ourselves. Are there any last resorts or is this pretty much it? If we can get it fixed for $500, that is less than a new one, but is it a good idea to spend that much on an 8 year old refrigerator?
Again, thanks guys for all your help, you've been more than great.
  #10 (permalink)
Old 11-13-2008, 05:05 AM
Senior Expert
APP Volunteer
Default
Yes and no. The government says that as long as it last ten years, that is satisfactory.
If you replace the compressor, ask about an extended warranty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compressor popping--new start relay/overload didn't help Taffin Refrigerator & Freezer Repair 5 03-29-2012 05:43 AM
Frigidaire Relay/Overload NLA so Need Generic Replacement dougo Refrigerator & Freezer Repair 3 01-08-2010 04:51 PM
Compressor Connections (Relay/Overload Protector) SouthWest Refrigerator & Freezer Repair 0 12-27-2009 05:02 PM
Compressor Clicking - Replaced relay and overload jmpjr99 Refrigerator & Freezer Repair 4 09-10-2009 01:06 PM
AMANA overload relay replacement cc703 Refrigerator & Freezer Repair 2 04-24-2008 07:14 AM
