Discuss
Not despencing water
 in
Refrigerator & Freezer Repair
The part# to fix the freezing water line on the GE SxS refer made between 2003 and 2007 is WR49x10173
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Not despencing water
  #21 (permalink)
Old 11-17-2008, 10:49 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Ads By Google
__________________
  #22 (permalink)
Old 11-20-2008, 08:11 AM
Junior Member
wb2nco is on a distinguished road
Default
I jumped online and found an inlet valve and installed. Wala!! Problem is fixed! Water now comes out of the dispenser! I now have 2 new valves after $50 in parts and my wife thinking that I'm overly obsessive!
Now another issue!
Water does not exactly stop coming out when I release the switch. It goes for about another 20-30 seconds. I have to stop about half way filling a glass. Also water does seem to come out a bit slower compared to what I have seen with other units. It might be normal, I'm not sure? Anyway, what can I do about the streaming water still coming out after I release the switch?
  #23 (permalink)
Old 11-20-2008, 08:34 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Run about a half a gallon of waterthru it to get all the air out of the lines and it should stop doing that.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #24 (permalink)
Old 11-21-2008, 09:22 AM
Junior Member
Default
I ran several gallons of water and it still runs quite a bit after depressing the button. Any other ideas?
  #25 (permalink)
Old 11-21-2008, 09:28 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Does your refer have a water tank reservoir, if it does, it will be behind one of your drawers in the freshfood section. if it does, you may have air trapped in that, take it off and turn it upside down and call for water, this will remove the air pocket in the tank
__________________
  #26 (permalink)
Old 11-21-2008, 10:52 AM
Junior Member
Default
Yes there is a tank inside the frig. Does it need to be filled entirely to start off? Should it always be full as I dispense water?
I assume water is drawn from the dispenser to the front of the door. Water then is pumped back in the tank from one of the valves? Should the tank always be full?
  #27 (permalink)
Old 11-21-2008, 10:59 AM
Senior Expert
APP Volunteer
Default
The tank should be full, if it has an air pocket in it you will have the symptoms you are getting do as abadfish stated above.
Nat
__________________
  #28 (permalink)
Old 11-22-2008, 11:50 AM
Junior Member
Default
That worked like a charm!! Thank you all for your help! This site helped me save time and money!!
  #29 (permalink)
Old 11-22-2008, 12:15 PM
Senior Expert
APP Volunteer
Default
Glad you were able to get it fixed!1
Nat
__________________
  #30 (permalink)
Old 11-22-2008, 04:47 PM
Junior Member
debbya is on a distinguished road
Default
Do you know where to find the valve if you have determined it is not working properly?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water lines to hook up to the water valve on a kenmore coldspot simonf22 Refrigerator & Freezer Repair 0 12-17-2009 12:16 PM
How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense Rashmikant Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
made clunking sound on ice and water dispenser now iced nor water works crazyman Refrigerator & Freezer Repair 1 09-08-2008 01:12 PM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
