Discuss
Refrig too warm
 in
Refrigerator & Freezer Repair
Side by side, freezer working great, the frig is too warm (60deg). The damper automatically closes when the power is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrig too warm
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-04-2007, 04:45 PM
doityourselfer doityourselfer is offline
Junior Member
doityourselfer is on a distinguished road
Default Refrig too warm
Model Number: 102.52603100   Brand: Kenmore   Age: 5 - 10 years
Side by side, freezer working great, the frig is too warm (60deg). The damper automatically closes when the power is turned on so I replaced the control board assembly. Still have the same problem $155 later. Do I try another part (such as the air diffuser assembly or even the thermistor)? I hate to keep buying parts unless I can get better guidance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-05-2007, 04:19 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check your model # it will not work
__________________
  #3 (permalink)
Old 10-08-2007, 07:43 AM
Junior Member
Default
What do you mean? The part will not work with the part I installed? The model is 106.52603100. The part number is 8201528.
  #4 (permalink)
Old 10-09-2007, 01:49 AM
Senior Expert
APP Volunteer
Default
You have a Whirlpool fridg. They always have the service sheet tucked under the front kick panel. Remove and check the thermistors for proper resistance.If off value just replace. While waiting for parts, unplug your damper motor and jam open 1/2 way the damper door.
__________________
  #5 (permalink)
Old 10-11-2007, 02:04 PM
Junior Member
Default
I have checked the service sheet as you suggested and ran the suggested diagnostics routine (I am assuming that is what you referred to with "check the thermistors for proper resistance) but they "passed". Any other ideas? What parts are you referring to "while waiting for parts"?
  #6 (permalink)
Old 10-11-2007, 05:12 PM
Senior Expert
APP Volunteer
Default
Your problem is impossible for me to figure out. Just order the thermistors, most probable problem even though they tested ok.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Refrig not cold in refer side pwatts Refrigerator & Freezer Repair 3 11-03-2007 08:24 AM
Side-by-Side: refrig warm, freezer cool tkrotchko Refrigerator & Freezer Repair 4 10-28-2007 07:19 PM
water backing up in the lower half of refrig. regiemister@hotmail.com Refrigerator & Freezer Repair 1 08-14-2007 10:50 AM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 08:06 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 05:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
