| » Quick connect leak |
Model Number: FRS6HR5HW1 Brand: Frigidaire Age: 1 - 5 years
After installation water line leaks at quick connect. 3 are fine only one leaks. All instructions were followed exactly. When the line that leaks was pushed on it went past o ring easily. The other lines pushed harder like the instructions said they would. What do I do now? Still leaking.
Quote:
PLT, Try pulling out on the leaking tube,slowly and slightly. That may pull the collar back out and lock it in place and stop the leak. You said you followed the instructions, So you're sure the end of the tube is cut straight, no burrs, etc. If tugging back on the tube, doesn't solve the problem, Re order a new valve assembly. ( You did order the part from AppliancePartsPros.com, I hope). Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
PLT,
Contact the APP Call Center 1-(877)-477-7278 Have your original order information available for them. Advise them, that you recieved a defective part, and need a new replacement part sent to you.
__________________
Quote:
Great, The APP Team, Takes care of their customers.
__________________
| Display Modes | |
| Qiuck connect | elesar | Refrigerator & Freezer Repair | 3 | 10-25-2010 02:08 PM |
| What does the ignitor connect to? | oc63rag | Oven Repair (including Ranges and Cooktops) | 5 | 10-18-2010 06:49 AM |
| GE Refrigerator Blud water line quick connect | reaganusa | Refrigerator & Freezer Repair | 3 | 07-02-2009 10:23 AM |
| Cannot connect my new electrode | Kelehan | Oven Repair (including Ranges and Cooktops) | 1 | 11-07-2008 07:59 PM |
