| » Evaporator Coils iced (refrigerator not cooling) |
Model Number: GSS221FPH Brand: GE Age: 1 - 5 years
Side-by-side GE Refrigerator is only cooling to 50 degrees, freezer to 10 degrees. I took off the inside panel in back of freezer, and the evaporator coils are completely iced over.
I took the panel off after I looked in the inside/back of the freezer and noticed a green wire with a clip on the end, that was hanging loose on the inside back of the freezer part. I can't see anyplace where it should be connected - but then everything is iced pretty heavily. If this is a ground wire, it may just have clipped to the metal frame someplace? Also, almost since the unit was new (came with the house), the refrigerator "moans" loudly for 10-20 minutes at a time - that noise has now ceased. I wonder if that is a circuit board? Thanks for any advice. Ads By Google Related Models |
Most likely there is a problem with the defrost system. You can find the complete troubleshooting instructions in one of our previous posts: Freezer is fine, refrigerator is too warm.
The green wire is a ground wire and was probably attached to the rear panel. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Freezer coils iced up, evap fan does not run | slg321 | Refrigerator & Freezer Repair | 0 | 06-13-2009 02:58 PM |
| Evaporator coils frozen - GE frig/freezer not cooling | rolltide23 | Refrigerator & Freezer Repair | 10 | 12-16-2008 08:48 AM |
| Freezer iced up refrigerator not cooling | ff36ike | Refrigerator & Freezer Repair | 5 | 12-11-2008 09:57 AM |
| Freezer coils iced up | dcrockett3 | Refrigerator & Freezer Repair | 1 | 11-29-2008 07:04 PM |
| Amana refrigerator freezer evaporator coils | RHCHomeowner | Refrigerator & Freezer Repair | 4 | 08-01-2008 04:02 AM |
