Ice dispenser flap in freezer door is hanging loose. I need the correct procedure to open this compartment up to determine the malfunction and parts that I need for repair.
Hello Gene:
Thank you for the information & diagram on the ice dispenser repair. This will be a great help. When I open it up & determine the parts needed, I will place an order. Thanks again, B. Garrett
