| » Frigidaire side by side |
Model Number: md20-5001 Brand: Frigidaire Age: 1 - 5 years
My refrigerator and freezer neith one cool. The blower works, but blows just air. I looked at changing out the control damper, part #240521103, Is this what I need to fix or am I looking in the wrong place?
Quote:
I cannot find any info on your given model number, please check it.
As kayakcrzy said the damper will not be the problem. It just regulates the amount of cold air entering the fresh food side of the unit. Since the freezer is not cold you simply do not have any cold air. First you have to determine if the compressor is running. You can usually hear it, also you should be able to feel it vibrating and it should be warm. If it is not running it could be the start device (kayakcrzy) or the freezer thermostat (control) or the compressor itself. If it is running then it may be a defrost problem, the freezer would be cold just not cold enough. If not a defrost problem then it will be a problem in the sealed system. Here are a couple good links on basic fridge repair. http://www.applianceaid.com/frig.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
| Display Modes | |
| Problem for Frigidaire Side by Side Refrigerator and Freezer | MMF3635 | Refrigerator & Freezer Repair | 0 | 08-23-2010 10:00 AM |
| Frigidaire Side by Side Ice/water Dispenser problems | alancorinn | Refrigerator & Freezer Repair | 0 | 07-28-2010 08:05 AM |
| Frigidaire side by side not cooling/freezing top half only | pcoppola | Refrigerator & Freezer Repair | 1 | 04-26-2010 04:04 PM |
| replace actuator switch on frigidaire side by side | elgerd | Refrigerator & Freezer Repair | 0 | 12-22-2009 07:54 AM |
| How do I change the water actuator on Frigidaire Side-by-side | Tosha1 | Refrigerator & Freezer Repair | 1 | 06-18-2009 03:24 PM |
