Never used. freezer door falls on your head. When they set it up was there an adjustment that should of been made or a rod removed. Please help. Need it. Head hurts and a stick slides. :confused:
The spring tension in the hinges is usually adjustable.
In this case I would get them back to get it fixed under warrant.
Something may be broken. Also if you break something trying to fix it, they could void your warranty. |
THIS FORUM IS DEAD!!!!!!! |
