Discuss
Small Uline Referigerator stopped getting cold
 in
Refrigerator & Freezer Repair
I have a Uline beverage center which is a small referigerator for holding drinks. It stopped getting cold and is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Small Uline Referigerator stopped getting cold
  #1 (permalink)
Old 11-13-2010, 07:26 AM
Junior Member
greatdeals_007 is on a distinguished road
Default Small Uline Referigerator stopped getting cold
Brand: -other-   Age: 1 - 5 years
I have a Uline beverage center which is a small referigerator for holding drinks. It stopped getting cold and is completely hot inside.
I am wondering if it would be worth fixing or not. Can you give me some suggestions on what the issue might be, estimate to fix?
I realize you would probably have to see it but then again people may have seen this issue before and would know what to look for.
thank you
Ads By Google
  #2 (permalink)
Old 11-14-2010, 04:20 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Check to see if the compressor is running.
You usually can hear it also you should be able to feel it vibrating and it should be warm.
If it is running then it is time to get a new unit as fixing it will cost more than it is worth.
If it has an interior light, does it work?
Is it making any noise re: clicking as the compressor tries to start?
__________________
  #3 (permalink)
Old 11-14-2010, 04:03 PM
Junior Member
mnagode is on a distinguished road
Default uline refridgerator does not cool
I have a uline 75r that has the same problem. The light works so I know it has power. I do not hear the compressor running running nor do I hear any clicking when I adjust the temp. control.
  #4 (permalink)
Old 11-15-2010, 02:56 AM
Senior Expert
APP Volunteer
Default
mnagode
I do not have info on the unit but it sounds like a simple fridge setup.
You could check to see if the compressor is getting power (120volts AC).
If not you probably have a thermostat problem.
Unplug the unit and measure across the thermostat contacts, should be 0 ohms.
Be sure to detach at least one wire to the thermostat. This prevents you from reading an alternate/parallel circuit path.
If you do not have a meter you could do the following jiggery pokery.
Unplug the unit.
If the thermostat has just 2 contacts, remove them from the thermostat.
Short them together.
Tape them up so they cannot short to anything else.
Plug the unit in.
If it fires up then your thermostat is shot.
If it is getting power then the following should help checking other components.
Here are a couple good links.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
  #5 (permalink)
Old 06-07-2011, 02:01 PM
Junior Member
whatsnext is on a distinguished road
Default
My 75FF uline combo only gets slightly cold. not enough for ice or even really to chill the cans surface. Fans work, compressor is running, coils are clean, but barely any cold air. Anyone have suggestions?
  #6 (permalink)
Old 06-07-2011, 05:38 PM
Senior Expert
APP Volunteer
Default
Not familiar with this unit but with luck it is a standard type of system.
Remove the freezer cover so you can see the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or only frost in one area then you have a compressor problem or are out of freon or are low on freon.
All of these will be expensive repairs so usually it makes more sense to invest those dollars in a new unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Referigerator odd cooling problem bgoans Refrigerator & Freezer Repair 6 01-03-2010 01:33 AM
Uline combo 75FF Icemaker on2mars Refrigerator & Freezer Repair 1 12-14-2009 02:57 PM
Referigerator repair Chan Patel Refrigerator & Freezer Repair 29 06-06-2009 11:08 AM
Stopped COLD while running,Control knobs just BUZZ fkukla Washer Repair 4 12-03-2008 06:44 PM
ULine 75R Door Unhinged bernjam Refrigerator & Freezer Repair 0 10-05-2008 07:51 PM
