| » Sub Zero 650 troubleshooting |
Model Number: 650 Brand: Sub Zero Age: 1 - 5 years
Hi all. I recently purchased a used sub zero 650 and am having an issue with it. I waited over 24 hours after it was delivered before I plugged it in because it was on its side. Two days after plugging it in and using it with no issues, a message appeared on the interior panel reading "vacuum condenser". I did some research to find out what I should do. I used a soft bristled brush attachment on my vacuum cleaner and cleaned the condenser on the top of the unit on the right hand side. Then I power cycled the unit. Ever since doing that, it seems as though the fridge is not working. It wont get below 44 degrees (its set at 38). I also dont hear the air flow when I open the fridge door anymore. It's almost as if the fridge is kinda holding the temperature without really working, it that makes any sense.
Any help would be greatly appreciated! Ads By Google Related Models |
I took the middle panel off on the back of the unit. Inside, there was a bundle of multi-colored wires, two brass tubes, an insulated tube and the water line. Nothing had any frost whatsoever on it. Where the insulated tube entered into the unit, there was some yellow insulation as well. That insulation was wet. Other than that, everything is dry as a bone.
It seems as though the fans are working ok. The exhaust that was coming out of the top of the unit is stronger now than it was before though. the temperatures read exactly what I have them set to: 0 for the freezer and 38 for the fridge. That damn "vacuum condenser" light is still on, however!!
| Display Modes | |
| Ice maker troubleshooting | pbxtxpbxtx | Refrigerator & Freezer Repair | 8 | 09-06-2010 08:13 PM |
| troubleshooting | georgep | Oven Repair (including Ranges and Cooktops) | 0 | 11-18-2009 08:23 AM |
| Troubleshooting | david8464 | Refrigerator & Freezer Repair | 3 | 10-03-2009 07:42 PM |
| dryer troubleshooting | seo | Dryer Repair | 1 | 08-02-2009 07:55 AM |
| troubleshooting help | johnl | Dryer Repair | 2 | 03-28-2008 02:31 AM |
