GE refrig no cooling after replace condenser(?) fan
replaced condenser fan (beside compressor) because it seemed to be causing burning smell. now the compressor doesn't start, fan in freezer doesn't come on, only the fan next to compressor runs (continuously). everything worked b4 fan replacement.
You probably have a burnt wire near the compressor, the evaporator fan only comes on when the evaporator is cold.
Quote:
When I disconnect the power or turn the refrig off/on the only response is the fan beside the compressor. What can I measure with VOM to test? |
Measure the voltage to the compressor, if nothing, I would re-post and ask for a schematic.
| All times are GMT -7. The time now is 04:30 AM. |
