| » Should it be fixed? |
Model Number: rtd 2300 cae Brand: Maytag Age: More than 10 years
I think our Maytag is acting up.
Clicking and alot of "on an off" cycling. should I start throwing parts at it or move on. Not one problem with it all these years, potential simple fix? Want to check electrical components, need info/ troubleshoot manual. Ads By Google Related Models Last edited by scotty tagfixer : 11-08-2010 at 04:08 PM. |
Pry off the cover on the side of the compressor, and replace the start device, square black item, AP2966871. This item is rather expensive,and rather reliable, but worth a try. Also, check for burnt wires at the compressor. If you have a meter, check for a compressor short to ground.
__________________
Quote:
Thanks for the reply. Will try and see what I find. Thanks again. how do you short a run capacitor? What kind of resistor do you use? Is it a must? |
Quote:
Have just enough of electrical knowledge to be dangerous. Thanks for having my back. |
Just had it all apart.
Everything looks good. compressor checks fine, didnt replace anything yet as I am wondering if there may have been some corrosion on a couple of terminals. Built Jan '94. It is back together and running with no issues... yet. now that feet are wet, comfortable with puttings parts into it. Thanks for input, greatly appreciate it. will keep updated. |
Been a couple of days, running much more normally but occasionally has its episodes like in past, not as often by far.
Since everything looked ok and compressor checked good, going to thro parts suggested at it and see if it continues. Still looking at connections and thinking I may have issue there since it is very intermitant now. Thanks again. Keep you posted... Last edited by scotty tagfixer : 11-12-2010 at 07:00 AM. |
When I order parts from this site, will they be as represented in pictures and exact replacements to original parts I have?
Will there be notification if there is a difference. In past have tried to get parts for appliances, only to have supplier tell me to hack this part in and it will work. Want something that conforms to original specs and fits original wiring. Thanks. |
| Display Modes | |
| Almost Fixed ! | Jack-99 | Washer Repair | 1 | 10-25-2009 11:55 AM |
| I think I fixed it? | Dremert | Refrigerator & Freezer Repair | 4 | 05-30-2009 12:14 PM |
| Fixed one problem, now have a new one | mlhayes | Refrigerator & Freezer Repair | 1 | 05-29-2009 03:54 PM |
| Thanks, washer fixed | miriammarie | Washer Repair | 0 | 04-17-2009 03:03 PM |
| Well, I thought it was fixed, but... | ssacrf | Oven Repair (including Ranges and Cooktops) | 3 | 06-30-2008 07:23 PM |
