Discuss
Door not sealing properly, tweaked door?
 in
Refrigerator & Freezer Repair
Hello, I've had my Imperial (seems to be Frigidaire now) UL5000ECW4 since 2000. The Commercial Manual Defrost Freezer still runs
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Door not sealing properly, tweaked door?
  #1 (permalink)
Old 11-04-2010, 10:43 PM
Junior Member
coachant is on a distinguished road
Default Door not sealing properly, tweaked door?
Model Number: UL5000ECW4   Brand: Frigidaire   Age: More than 10 years
Hello,
I've had my Imperial (seems to be Frigidaire now) UL5000ECW4 since 2000. The Commercial Manual Defrost Freezer still runs like a tank! The only issue I have is that the top left corner (opposite side of hinges) will not seal. I did notice the lower right gasket corner was folded in just a little and about 8 inches of the gasket on the bottom was not locked in under plastic rail. I reattached the gasket on the bottom of the door. After looking at the post in this forum I used a hair dryer to straighten out the gasket on the bottom right by the lower hinge. I also taped the door shut on the top left to get it to seal. Hopefully it works!
The Freezer is used for a daycare and the ladies are not the nicest to this tank. On top of everything I suspect that the door may be tweaked. Other posts mention that the door is a 2 piece door and the screws need to be removed and the door realigned on a flat surface. I'm going to see how things look tomorrow and then take a look at the hinges if there are still issues (also got the idea from the forum).
I haven't heard the door seal (vacuum sound) in about 6 months. The freezer will form ice so it does seem like a seal issue.
How exactly does the door self seal? The door seems to suck in when working properly. Is any mechanical device that aids in the evacuation of air? I'd really like to know.
Thanks!
Anthony
Related Models
Frigidaire UL5000ECW4
Frigidaire UL5000ECW5 TOP MOUNT REFRIGERATOR
Frigidaire UL5000ECW7
Amana ULD510 COMMERCIAL MICROWAVES
Amana ULD510M COMMERCIAL MICROWAVES
Amana ULD510S COMMERCIAL MICROWAVES
Amana UM2000C COMMERCIAL MICROWAVES
Amana UM2100.000 COMMERCIAL MICROWAVES
Amana UM3100.000 COMMERCIAL MICROWAVES
Maytag UMC1061AAB MWAVE- CNTRTP / STAND ALONE
Maytag UMC1061AAW MWAVE- CNTRTP / STAND ALONE
Maytag UMC1071AAB MWAVE- CNTRTP / STAND ALONE
Maytag UMC1071AAW MWAVE- CNTRTP / STAND ALONE
Maytag UMC5100ADB MWAVE- CNTRTP / STAND ALONE
Maytag UMC5100ADQ MWAVE- CNTRTP / STAND ALONE
Maytag UMC5100ADS MWAVE- CNTRTP / STAND ALONE
Maytag UMC5100ADW MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200AAB MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200AAQ MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200AAS MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200AAW MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200BAB MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200BAS MWAVE- CNTRTP / STAND ALONE
Maytag UMC5200BAW MWAVE- CNTRTP / STAND ALONE
Whirlpool UMC5200BCB10 COUNTERTOP MICROWAVE 2.0 CU. FT.
Whirlpool UMC5200BCS10 COUNTERTOP MICROWAVE 2.0 CU. FT.
Whirlpool UMC5200BCW10 COUNTERTOP MICROWAVE 2.0 CU. FT.
Amana UMLD10E COMMERCIAL MICROWAVES
Amana UMLD10M COMMERCIAL MICROWAVES
Amana UMLD10SE COMMERCIAL MICROWAVES
Amana UMLD10SS Commercial Microwaves
Menu Master UMLD510 COMMERCIAL MICROWAVES
Menu Master UMLD510D COMMERCIAL MICROWAVES
Amana UMP1.A COMMERCIAL MICROWAVES
Maytag UMV1142AAB MWAVE- MOUNTED UNDER CABINET
Maytag UMV1142AAQ MWAVE- MOUNTED UNDER CABINET
Maytag UMV1142AAW MWAVE- MOUNTED UNDER CABINET
Maytag UMV1142ACB MWAVE- MOUNTED UNDER CABINET
Maytag UMV1142ACQ MWAVE- MOUNTED UNDER CABINET
Maytag UMV1142ACW MWAVE- MOUNTED UNDER CABINET
Maytag UMV1152AAB MWAVE- MOUNTED UNDER CABINET
Maytag UMV1152AAQ MWAVE- MOUNTED UNDER CABINET
Maytag UMV1152AAW MWAVE- MOUNTED UNDER CABINET
Maytag UMV1152BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag UMV1152BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag UMV1152BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag UMV1152BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag UMV1152CAB MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV1152CAB16 MICROWAVE OVEN/HOOD 1.5 CU. FT.
Maytag UMV1152CAQ MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV1152CAQ16 MICROWAVE OVEN/HOOD 1.5 CU. FT.
Maytag UMV1152CAS MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV1152CAS16 MICROWAVE OVEN/HOOD 1.5 CU. FT.
Maytag UMV1152CAW MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV1152CAW17 MICROWAVE OVEN/HOOD 1.5 CU. FT.
Maytag UMV2186AAB MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV2186AAB14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool UMV2186AAB16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag UMV2186AAS MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV2186AAS14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool UMV2186AAS16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag UMV2186AAW MWAVE- MOUNTED OVER RANGE/WO
Whirlpool UMV2186AAW15 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool UMV2186AAW17 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Magic Chef UN34FA-3EKX-NDV RANGE- S/C F/S GAS
Magic Chef UN34FA-92CK-N RANGE- S/C F/S GAS
Magic Chef UN34FG-92CK-N RANGE- S/C F/S GAS
Magic Chef UN34FN-3EKX-NDV RANGE- S/C F/S GAS
Magic Chef UN34FN-92CK-N RANGE- S/C F/S GAS
Magic Chef UN34FY-92CK-N RANGE- S/C F/S GAS
Norge UNGA2H0 RANGE- F/S STD GAS
Norge UNGA2H1 RANGE- F/S STD GAS
Norge UNGA2HK0 RANGE- F/S STD GAS
Norge UNGA2HK1 RANGE- F/S STD GAS
Norge UNGA3G1 RANGE- F/S STD GAS
Norge UNGA3G2KV RANGE- F/S STD GAS
Norge UNGA3G2LNX RANGE-F/S CONT CLEAN GAS
Norge UNGA3G2LNX-BO RANGE-F/S CONT CLEAN GAS
Norge UNGA3G2NX RANGE- F/S STD GAS
Norge UNGA3G2NX-BO RANGE- F/S STD GAS
Norge UNGA6H2GLNW RANGE-F/S CONT CLEAN GAS
Norge UNGA6H2GLNW-AD RANGE-F/S CONT CLEAN GAS
Norge UNGC3G1 RANGE- F/S STD GAS
Norge UNGCA82-1 RANGE- F/S STD GAS
Norge UNGCA83-1G-11 RANGE- F/S STD GAS
Norge UNGCW82-1 RANGE- F/S STD GAS
Norge UNGCW83-1G-11 RANGE- F/S STD GAS
Norge UNGF3G1 RANGE- F/S STD GAS
Norge UNGH3G1 RANGE- F/S STD GAS
Norge UNGHA82-1 RANGE- F/S STD GAS
Norge UNGHW82-1 RANGE- F/S STD GAS
Norge UNGW2H0 RANGE- F/S STD GAS
Norge UNGW2H1 RANGE- F/S STD GAS
Norge UNGW2HK0 RANGE- F/S STD GAS
Norge UNGW2HK1 RANGE- F/S STD GAS
Norge UNGW3G1 RANGE- F/S STD GAS
Norge UNGW3G2KV RANGE- F/S STD GAS
Norge UNGW3G2LNX RANGE-F/S CONT CLEAN GAS
Norge UNGW3G2LNX-BO RANGE-F/S CONT CLEAN GAS
Norge UNGW3G2NX RANGE- F/S STD GAS
Norge UNGW3G2NX-BO RANGE- F/S STD GAS
Norge UNGW6H2GLNW RANGE-F/S CONT CLEAN GAS
Norge UNGW6H2GLNW-AD RANGE-F/S CONT CLEAN GAS
Maytag UNVIM98 MISC / ACCESSORY
Amana URC517MP COMMERCIAL MICROWAVES
Amana URCS511 COMMERCIAL MICROWAVES
Amana URCS511A COMMERCIAL MICROWAVES
Amana URFS511 COMMERCIAL MICROWAVES
Amana URFS518S COMMERCIAL MICROWAVES
Amana URS511 COMMERCIAL MICROWAVES
Amana URS511M COMMERCIAL MICROWAVES
Amana URS511MB COMMERCIAL MICROWAVES
Amana URS511P COMMERCIAL MICROWAVES
  #2 (permalink)
Old 11-05-2010, 02:26 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for FRIGIDAIRE UL5000ECW4 | AppliancePartsPros.com
I do not know this. Hopefully someone else will jump in with this info.
Some seals do have a magnetic strip built into them.
Not in evacuating air but in holding the door closed yes.
The door's lower hinge does have a set of ramps that aid in keeping the door closed. The door rides up and over these ramps so that when it is closed it is on the down ramp holding the door closed. See Item 22A in Section 1 and Item 26 in Section 2 of the parts, if you click on the part's picture you should be able to expand it to get a better view.
Perhaps one of theses is broken as they are plastic.
It is fairly common for a seal to grab onto the frame and not seal properly. A light coating of vaseline or white lithium grease prevents this especially on the hing side.
Also make sure the unit is level or leaning slightly to the back.
__________________
  #3 (permalink)
Old 11-05-2010, 02:30 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You can try duck tape to hold the door shut overnight, if gasket is still good, that should fix it.
If you stick a dollar bill between the gasket and frame, it should be hard to remove it, if very easy, you have a bad gasket.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
door not sealing carl reed Refrigerator & Freezer Repair 1 03-06-2010 02:31 AM
oven door not sealing properly retiree Oven Repair (including Ranges and Cooktops) 0 09-18-2009 12:04 PM
Freeze door not sealing southsidequeen Refrigerator & Freezer Repair 5 06-23-2009 11:32 AM
Whirlpool door not sealing Givethanx Refrigerator & Freezer Repair 0 08-26-2008 10:47 AM
Freezer door not sealing RadRick Refrigerator & Freezer Repair 1 08-08-2007 05:49 PM
