I have a Whirlpool freezer on top fridge Mod GT1SHTXMT01. For a while it didn't seem to be getting cold enough so I emptied it, clean it and let it totally thaw out. When I plugged it back in it seemed to work fine but then it quit. The lights still work inside but nothing else. Any ideas???
I went back in to make sure I didn't knock anything loose while I was vacuuming and when I plugged it back in it started working. Not sure yet if it will get cold so I might still have a problem.
Originally Posted by: Ryley I went back in to make sure I didn't knock anything loose while I was vacuuming and when I plugged it back in it started working. Not sure yet if it will get cold so I might still have a problem. Still quits working before it gets cold enough.
Now it doesn't even come on:mad:
