I've had this thing repaired a few times 8-10 years ago or so, but I came back from a long trip and the fridge was not cold at all.
After disassembling, the refrige compartment fan (top center) was not working. Lights worked. Plugging the fan into the light connector and the fan works, so it doesn't appear to be a bad fan. There doesn't seem to be any power on the refrige fan. I assume its not a power issued, but some other component that drives the fan.
What should I check?
Thanks,
Darrin
