Discuss
GE Side /Side not cooling
 in
Refrigerator & Freezer Repair
Originally Posted by Clints66 Ge Side by side not cooling fan runing but compressor not kicking in ? Checked Coils
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Side /Side not cooling
  #11 (permalink)
Old 10-31-2010, 10:26 AM
Junior Member
Jack Powers is on a distinguished road
Default
Quote:
Originally Posted by Clints66 View Post
Ge Side by side not cooling fan runing but compressor not kicking in ? Checked Coils in freezer not iced up ! Motor board ? Relay ? Thermostat ? any help would be great also how do you check any or all ? Thanks Clint
The fan motor is failing,I have the replacement part # but it gives me two choices. One with a thermistor and one without. The serial number of my refrig is FH401198.The two parts are AP3191003 with the thermistor and AP3875639 without. Please advise which to order. Thank you, Jack
  #12 (permalink)
Old 10-31-2010, 10:33 AM
Junior Member
Question
Quote:
  #13 (permalink)
Old 11-01-2010, 07:35 AM
Senior Member
applianceman is on a distinguished road
Default
Clints66
The door being ajar can cause problems but it will not cause the compressor not to run.
The condenser is a no-clean condenser. Meaning that the condenser will get dirty but it will not affect the workings of the refrigerator. In any case it will not hurt to clean it.
There is a chance that the compressor relay is the problem but typically you will hear the clicking like the compressor is starting (you say you didn’t hear that). Also the relay isn’t typically an intermitting problem. You say it when back to work so whatever it is, it is intermitting. I know you don’t what to wait for this to fail again but it will be the best way to tell the problem.
When/if it happens again you need to know if the fans are running, if the compressor is running (and if it is not is it hot or room temp) and is it cooling at all?
  #14 (permalink)
Old 11-01-2010, 10:49 AM
Junior Member
Clints66 is on a distinguished road
Cool GE side by side
Quote:
Originally Posted by applianceman View Post
Clints66
There is a chance that the compressor relay is the problem but typically you will hear the clicking like the compressor is starting (you say you didnít hear that). Also the relay isnít typically an intermitting problem. You say it when back to work so whatever it is, it is intermitting. I know you donít what to wait for this to fail again but it will be the best way to tell the problem.
[quote=Clints66] First I would like to thank you for all your Help. I will keep an eye on it, This refrig is in the garage. I put it out there a 3+ years ago when we remodeld the kitchen. When I found the freezer door open it was ajar all night long..I thought it would be ok after I shut the door and went to work. When I got home my wife said it never go cold. I originaly thought it was iced up ? I unplugged for 1 day doors open plugged it back in nothing happened. I then started taking stuff apart the condenser coil looked like it had a sock on it thats how bad it was..! I vacuumed it off waited 1 more day as I was emailing back and forth trying to figure out what to look for plugged it back in and I heard the compressor ? checked the coils in the freezer as I still had the pannels off and the coils were starting to frost so I put it all back together and she is still working.
  #15 (permalink)
Old 11-01-2010, 11:06 AM
Junior Member
TrvlngSldr2006 is on a distinguished road
Default
First I have a Whirlpool model GD2LHGXKQ00 fridge, compressor is the EGY80. My problem was originally the fridge not cooling. Found out the start relay was bad. I ordered the start relay kit (8201786). I installed the PTC relay into the top two pegs on the compressor (hooked up the white wire) and installed the overload protector (part number 2187145) into the bottom peg (hooked up the red wire). My fridge does not have the blue wire like some talk about. Too easy, right? Once I plugged the fridge back in, the fan came on, the compressor came on. The fridge was cooling again. About 15 minutes later everything went dead and there was a burning smell coming from inside the fridge. I pulled the fridge back out, took the bottom piece back off and noticed that the fan was not working nor the compressor. The compressor was hot. I opened the fridge doors and the lights came on. So the fridge was still getting power right? I checked the circuit breaker out in the garage and all fuses were good to go. None blown. I unplugged the fridge and now confused on what is next. I plugged the fridge back up after several hours and can hear a crackling noise coming from the back area where the compressor and other components are located. Should I order the kit (8201786) and try again, call the repairman, buy a compressor or a new fridge? Any suggestions on what could have possibly happened?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore side by side model clicks and buzzes every 60-120 seconds and stopped cooling 67rustang Refrigerator & Freezer Repair 2 05-03-2012 10:02 AM
kenmore side by side fridge/freezer not freezing or cooling tspires Refrigerator & Freezer Repair 4 10-24-2010 10:12 AM
Refridgerator side-by-side not cooling (refridge side) rrvolfan Refrigerator & Freezer Repair 2 05-31-2010 12:10 PM
Side by Side fridge and freezer not cooling and making no ice! krm208 Refrigerator & Freezer Repair 1 07-11-2008 07:41 PM
side by side ice and water in door not cooling or freezing Anna1441 Refrigerator & Freezer Repair 0 06-26-2008 08:11 AM
