Discuss
compressor hot, fridge and freezer not cooling
 in
Refrigerator & Freezer Repair
kenmore side by side fan working, compressor hot, when compressor tested with unit off checked for open windings by ohms
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » compressor hot, fridge and freezer not cooling
  #1 (permalink)
Old 10-26-2008, 08:07 PM
jeansto jeansto is offline
Junior Member
jeansto is on a distinguished road
Default compressor hot, fridge and freezer not cooling
Brand: Kenmore   Age: 5 - 10 years
kenmore side by side fan working, compressor hot, when compressor tested with unit off checked for open windings by ohms found resistence leg to leg, do we need a new compressor?
  #2 (permalink)
Old 10-27-2008, 05:36 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
maybe just a relay
__________________
  #3 (permalink)
Old 10-27-2008, 06:40 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Its a Kenmore, the overload and relay combination have a history of going out. I bet that is it. Tom ApplianceEducator.com
  #4 (permalink)
Old 10-27-2008, 08:08 AM
icehouse icehouse is offline
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Quote:
Hey Tom, see you are over here also.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. Vist www.hvacbob.com
  #5 (permalink)
Old 10-27-2008, 05:10 PM
Senior Expert
APP Volunteer
Default
You now me, the Appliance Guru. Tommy boy
  #6 (permalink)
Old 10-27-2008, 05:22 PM
Senior Expert
APP Volunteer
Default
Yup. Sheilas forum is loaded with garbage ads. What 's up with that.
__________________
  #7 (permalink)
Old 10-27-2008, 06:01 PM
Oxebo69 Oxebo69 is offline
Junior Member
Oxebo69 is on a distinguished road
Default How to check resistance first! :)
You have 3 pin (triangle) you have to check with a Ohm meter how to check:
Common : Is the biggest resistance
Start: Medium
Run: Smallest
If you see that all of them are almost the same it means shorted or if you touch one of those pins with a pipe & you have a continuity it means its shorted 2.
Hope it was Helpful!
  #8 (permalink)
Old 10-27-2008, 06:30 PM
Senior Expert
APP Volunteer
Default
Start: Medium
Run: Smallest
Start is the largest resistance, not Common.
The total resistance between Run and Start should equal the sum of Start to Common and Run to Common.
Example: C to S = 5 Ohms, C to R = 2 Ohms, Then C to S = 7 Ohms
Testing for Grounds: Using an Ohmmeter place one probe on a good ground
such as the ground screw on the compressor. The other probe should then be placed on one of the pins as so stated. If you get a reading, the compressor is grounded.
Testing for open windings: Using an Ohmmeter take the leads and test between any two pins. Reading infinity compressor has open windings.
Testing for shorts: Using an Ohmmeter, place the leads between any two pins. Reading zero shorted compressor.
So much for "Compressors 101"
__________________
  #9 (permalink)
Old 10-28-2008, 05:05 AM
Senior Expert
APP Volunteer
Default
nicely done Icehouse lol
__________________
  #10 (permalink)
Old 10-28-2008, 05:15 AM
Senior Expert
APP Volunteer
Default
Thanks. I love what I have been doing for forty years now. God I'm getting old.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge and freezer not cooling cher Refrigerator & Freezer Repair 0 09-02-2008 02:47 PM
Fridge/Freezer Compressor cycling on and off dmeyer4 Refrigerator & Freezer Repair 0 08-07-2008 07:37 PM
Freezer/Fridge not cooling info@georgiainsuranceagen Refrigerator & Freezer Repair 3 04-08-2008 02:31 PM
fridge and freezer not cooling estock Refrigerator & Freezer Repair 7 03-30-2008 12:11 PM
Fridge and Freezer NOT cooling Dede Refrigerator & Freezer Repair 0 11-28-2007 09:44 AM
