| » Repair rip off question |
Depends where the frost is.
If it is on the freezer walls and food then it may be a door leak. Either the freezer or the fresh food door is letting moist warm air in and it is condensing on the walls etc. Take a 2 inch strip of paper and place it between the door seal and the unit's frame. Then pull it out to see if the door is sealing correctly. Work your way around both doors. Also sometimes the door seal can grab on the hinge side and cause it to not seal properly. A fix for this is a light coating of vaseline or white lithium grease along this side. Also check that the doors are still square with the frame and that the door cams are OK. Cams are plastic ramp type parts at the bottom hinge, they help close/seal the door when it is closed. Most units have cams. If the frost is on the evaporator coils then it could be a defrost problem. The frost/ice must build up to the point that the evaporator fan cannot pull air through the coils. Early symptoms are a higher temperature in the fresh food side and the unit running more often or constantly. A defrost problem can be the defrost heater, the defrost thermostat or the control board (depending on the unit). It must be troubleshot to determine which.
__________________
- Last edited by denman : 10-25-2010 at 04:06 AM. |
Quote:
Thanks for the advice. The freezer is running constantly. Is this sucking up major energy? |
| Display Modes | |
| Dishwasher Repair Question | rochester,mn | Dishwasher Repair | 5 | 09-09-2010 04:37 AM |
| Repair question | Mark Weidner | Washer Repair | 1 | 01-18-2010 07:30 AM |
| GE Profile Repair Question | DAndrys | Dryer Repair | 5 | 11-18-2009 01:13 PM |
| Repair question | rsingh2483 | Refrigerator & Freezer Repair | 1 | 02-22-2009 05:10 PM |
| Help with a repair question | jillc | Oven Repair (including Ranges and Cooktops) | 2 | 02-21-2009 01:36 PM |
