Discuss
help
 in
Refrigerator & Freezer Repair
1999 roper refrigerator mod#rt18dkxhw00 unit has started leaking water from the air tower area, it puddles up on the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » help
  #1 (permalink)
Old 09-30-2007, 03:04 AM
cr8trnd cr8trnd is offline
Junior Member
cr8trnd is on a distinguished road
Question help
Model Number: rt18dkxhw00   Brand: Roper   Age: 5 - 10 years
unit has started leaking water from the air tower area, it puddles up on the inside floor of refrigerator. how do i fix this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-30-2007, 04:00 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Your freezer pan is filled with water, just remove freezer bottom panel and back panel with tower.
You will find the drain frozen up. I use boiling water and a turkey baster to unfreeze the drain.
After it is thawed, I wrap a piece of heavy gauge copper wire around the defrost heater and down the drain. This should fix the problem.
__________________
  #3 (permalink)
Old 09-30-2007, 06:39 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
This may also help you out.
Repair Video
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
