have this 5 year old kenmore with 2 problems. problem 1. Freezer is not defrosting. From parts list I do not see a timer to control defrost cycle. How do i troubleshoot if its the bi metal, heater coil or circuit board? problem 2 Ice maker is not getting water to the cube tray. Water dispenser on front of fridge has good flow. Thanks for your help. Dan
