Ice maker ejection system cycles when toggle switch is pressed continuosly but seems to stop when the switch is released. Water is not filling the tray but is available for the water dispenser. The switch does not appear to remain in the | position but goes back to neutral. I have also seen a spark in the toggle area. Is it the switch? What parts should I replace? How do you remove the icemaker unit to from the freezer? Do I need any special tools?
