Evap Fan not spinning (Voltage 18-20); Compressor vibrating but not getting hot; Condenser Fan spinning; Condenser not hot. The relay or overload is clicking on and off.
Continuity checked ok on all of the compressor terminals.
Started by replacing the evap fan. After this the fridge worked ok for long enough to make some ice - then eventually the fan stopped working again.
Replaced the defrost timer (which looked fried) but apparently that was not it.
Whats next?
