| » freezer not freezing, frig o.k. |
Model Number: FRS6R5ESBC Brand: Frigidaire Age: 1 - 5 years
freezer not freezing, no ice on coils, compressor runs constantly until you turn temp control down then shuts off, turn temp control back up and compressor kicks on again. not sure if this is a thermostat problem or something more costly. any help would be great. thanks
When you checked the evaporator coils was there any frost on them?
Since you said the fresh food side is getting some cooling there should have been some frost. Note: That you have to check them after the unit has run for a couple hours. This is to ensure that you do not check them just after a defrost cycle which would have removed all the frost. If there is only frost in one area, usually where the freon enters the coils or the frost pattern is very blotchy, then odds are you are low on freon. Here is a good link http://www.applianceaid.com/refrigerator.html Check out #20 and then the example pictures part way down the page. If it is a low freon condition you will have to get a pro in to repair it. Often it makes more sense to replace the unit as finding/repairing the leak and then recharging the system will be expensive.
__________________
when i looked behind the freezer, the coils were very dusty but didn't have any frost/ice on them. the frig/freezer had been running prior to me checking it, i cleaned all the dust of the coils (and everywhere else) thinking that might have been the problem but no dice. i have looked at the schematics on your web site and am not sure if it could be the thermostat, the defrost timer, or something else.
Here is the parts breakdown
Replacement parts for FRIGIDAIRE FRS6R5ESBC Frigidaire/refrigerator | AppliancePartsPros.com when i looked behind the freezer, the coils were very dusty but didn't have any frost/ice on them. I think you may have been looking at the wrong coils. I have never seen dusty evaporator coils. Dusty condenser coils is the norm so that is why I think you were looking at them. You want the coils in the freezer (Item 15 in Section 6) am not sure if it could be the thermostat, It will not be the thermostat since it is telling the compressor to run and it is. the defrost timer If the evaporator coils are free of frost/ice it is not a defrost problem. Read more: freezer not freezing, frig o.k. http://forum.appliancepartspros.com
__________________
Your unit uses an adaptive defrost control (Item 21 in Section 2)
Here is the tech sheet for this unit http://manuals.frigidaire.com/prodin.../240389629.pdf
__________________
o.k. took the cover off the inside of the freezer after my wife unplugged it for a day everything looked fine (no ice/frost). plugged the frig back in let it run overnight with frig & freezer turned up to max cold and this morning neither were cold. the tube that enters the evaperator coils in the back of the freezer was coated with ice/frost as well as the top third of the top row of coils. compressor is running as well as fan below and so is the fan above the evaperator coils. you said something about low freon, is there a way to check that? thanks again for all your help
It does sound like low freon.
http://www.applianceaid.com/frig_notcold.html Take a look at example pictures part way down the page. Only other way to check it is with a set of guages and you will need a pro for that.
__________________
| Display Modes | |
| Freezer is good - Frig keeps freezing | ssmueller | Refrigerator & Freezer Repair | 1 | 09-14-2010 03:49 AM |
| Freezer not freezing food, Frig seems to be ok | prekojo | Refrigerator & Freezer Repair | 7 | 07-30-2010 09:19 AM |
| coils freezing up in freezer and frig temps warm | dhofer | Refrigerator & Freezer Repair | 3 | 06-02-2009 06:01 PM |
| frig not cooling freezer not freezing | claychapman | Refrigerator & Freezer Repair | 1 | 04-30-2009 10:57 AM |
| Freezer Part Of Frig Stopped Freezing | ESETKO | Refrigerator & Freezer Repair | 2 | 10-04-2007 02:17 PM |
