Mold tray on 106-626663 has no water.
Performed optics test, 2 pulses followed by pause. Led then steady when holding paddle.
Checked fill tube no blockage, Cut tube in back going to water fill and could blow through, reconnect line with quick splice. Removed connector at water valve coil and applied 115 V and valve opens and water flows to nozzle and tray.
Performed T to H motor jump and motor cycles but no power is sent to water valve after 10 oclock position. Perform L to V power jump and no power to water valve.
Primed tray and maker does not empty ice.
Performed component diagnostics and recieved 3 pulses of led when opening freezer door.
Do I need a new maker AP3182733?
Thanks for your help Craig
