Discuss
Exchanger frosting up at bottom
 in
Refrigerator & Freezer Repair
I have an older (15+y/o) refrigerator with the freezer on top and no ice maker. Recently, the part #AP3004441, labeled
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Exchanger frosting up at bottom
  #1 (permalink)
Old 10-21-2008, 09:49 AM
Junior Member
fltsurg is on a distinguished road
Question Exchanger frosting up at bottom
Model Number: ET16JK1M   Brand: Whirlpool   Age: More than 10 years
I have an older (15+y/o) refrigerator with the freezer on top and no ice maker. Recently, the part #AP3004441, labeled "exchanger" in the diagram, has begun building up a heavy layer of frost at the bottom, metal, C-shaped area. Is this a simple block that I can clear or, because of the refrigerant, something a trained tech should repair? TIA
Ads By Google
Related Models
Whirlpool ET16JK1MWL1 Refrigerators*
Whirlpool ET16JK1MWR1 Refrigerators*
Whirlpool ET16JK1MWR2 Refrigerators*
Whirlpool ET16JK1MWR3 Refrigerators*
Whirlpool ET16JKSXW02 REFRIGERATORS
Whirlpool ET16JKXBN00 REFRIGERATORS
Whirlpool ET16JKXBN01 REFRIGERATORS
Whirlpool ET16JKXBW00 REFRIGERATORS
Whirlpool ET16JKXBW01 REFRIGERATORS
Whirlpool ET16JKXDN00 REFRIGERATORS
Whirlpool ET16JKXDN01 REFRIGERATORS
Whirlpool ET16JKXDN02 REFRIGERATORS
Whirlpool ET16JKXDN03 REFRIGERATORS
Whirlpool ET16JKXDW00 REFRIGERATORS
Whirlpool ET16JKXDW01 REFRIGERATORS
Whirlpool ET16JKXDW02 REFRIGERATORS
Whirlpool ET16JKXDW03 REFRIGERATORS
Whirlpool ET16JKXHN00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JKXHW00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JKXLWL0 Refrigerators*
Whirlpool ET16JKXLWR0 Refrigerators*
Whirlpool ET16JKXMWR0 Refrigerators*
Whirlpool ET16JKXRWR0 Refrigerators*
Whirlpool ET16JKXRWR1 Refrigerators*
Whirlpool ET16JKXRWR2 Refrigerators*
Whirlpool ET16JKXRWR3 Refrigerators*
Whirlpool ET16JKXSF01 REFRIGERATOR
Whirlpool ET16JKXSF02 REFRIGERATOR
Whirlpool ET16JKXSG01 REFRIGERATOR
Whirlpool ET16JKXSG02 REFRIGERATOR
Whirlpool ET16JKXSM01 REFRIGERATOR
Whirlpool ET16JKXSM02 REFRIGERATOR
Whirlpool ET16JKXSN01 REFRIGERATOR
Whirlpool ET16JKXSN02 REFRIGERATOR
Whirlpool ET16JKXSW00 Refrigerators*
Whirlpool ET16JKXSW01 REFRIGERATOR
Whirlpool ET16JKXSW02 REFRIGERATOR
Whirlpool ET16JKXSW03 REFRIGERATORS
Whirlpool ET16JKXWF00 REFRIGERATORS
Whirlpool ET16JKXWG00 REFRIGERATORS
Whirlpool ET16JKXWM00 REFRIGERATORS
Whirlpool ET16JKXWN00 REFRIGERATORS
Whirlpool ET16JKXWN01 REFRIGERATORS
Whirlpool ET16JKXWW00 REFRIGERATORS
Whirlpool ET16JKXWW01 REFRIGERATORS
Whirlpool ET16JKYBN00 REFRIGERATORS
Whirlpool ET16JKYBN01 REFRIGERATORS
Whirlpool ET16JKYBW00 REFRIGERATORS
Whirlpool ET16JKYBW01 REFRIGERATORS
Whirlpool ET16JKYDN00 REFRIGERATORS
Whirlpool ET16JKYDN01 REFRIGERATORS
Whirlpool ET16JKYDN02 REFRIGERATORS
Whirlpool ET16JKYDN03 REFRIGERATORS
Whirlpool ET16JKYDW00 REFRIGERATORS
Whirlpool ET16JKYDW01 REFRIGERATORS
Whirlpool ET16JKYDW02 REFRIGERATORS
Whirlpool ET16JKYDW03 REFRIGERATORS
Whirlpool ET16JKYHN00 REFRIGERATOR
Whirlpool ET16JKYHW00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JKYSF01 REFRIGERATOR
Whirlpool ET16JKYSF02 REFRIGERATOR
Whirlpool ET16JKYSF03 REFRIGERATORS
Whirlpool ET16JKYSG01 REFRIGERATOR
Whirlpool ET16JKYSG02 REFRIGERATOR
Whirlpool ET16JKYSG03 REFRIGERATORS
Whirlpool ET16JKYSM01 REFRIGERATOR
Whirlpool ET16JKYSM02 REFRIGERATOR
Whirlpool ET16JKYSM03 REFRIGERATORS
Whirlpool ET16JKYSN01 REFRIGERATOR
Whirlpool ET16JKYSN02 REFRIGERATOR
Whirlpool ET16JKYSN03 REFRIGERATORS
Whirlpool ET16JKYSW00 Refrigerators*
Whirlpool ET16JKYSW01 REFRIGERATOR
Whirlpool ET16JKYSW02 REFRIGERATOR
Whirlpool ET16JKYSW03 REFRIGERATORS
Whirlpool ET16JKYWF00 REFRIGERATORS
Whirlpool ET16JKYWG00 REFRIGERATORS
Whirlpool ET16JKYWM00 REFRIGERATORS
Whirlpool ET16JKYWN00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JKYWW00 REFRIGERATORS
Whirlpool ET16JM1MWR1 Refrigerators*
Whirlpool ET16JM1MWR2 Refrigerators*
Whirlpool ET16JM1MWR3 Refrigerators*
Whirlpool ET16JMXBN00 REFRIGERATORS
Whirlpool ET16JMXBN01 REFRIGERATORS
Whirlpool ET16JMXBW00 REFRIGERATORS
Whirlpool ET16JMXBW01 REFRIGERATORS
Whirlpool ET16JMXDN00 REFRIGERATORS
Whirlpool ET16JMXDN01 REFRIGERATORS
Whirlpool ET16JMXDN02 REFRIGERATORS
Whirlpool ET16JMXDW00 REFRIGERATORS
Whirlpool ET16JMXDW01 REFRIGERATORS
Whirlpool ET16JMXDW02 REFRIGERATORS
Whirlpool ET16JMXHN00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JMXHW00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JMXLWR0 Refrigerators*
Whirlpool ET16JMXMWR0 Refrigerators*
Whirlpool ET16JMXRWR0 Refrigerators*
Whirlpool ET16JMXRWR1 Refrigerators*
Whirlpool ET16JMXRWR2 Refrigerators*
Whirlpool ET16JMXRWR3 Refrigerators*
Whirlpool ET16JMXRWR4 REFRIGERATOR
Whirlpool ET16JMXSW00 Refrigerators*
Whirlpool ET16JMXSW01 Refrigerators*
Whirlpool ET16JMXSW02 REFRIGERATORS
Whirlpool ET16JMXSW03 REFRIGERATORS
Whirlpool ET16JMXSW04 REFRIGERATORS
Whirlpool ET16JMYBN00 REFRIGERATORS
Whirlpool ET16JMYBN01 REFRIGERATORS
Whirlpool ET16JMYBW00 REFRIGERATORS
Whirlpool ET16JMYBW01 REFRIGERATORS
Whirlpool ET16JMYHN00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JMYHW00 TOP MOUNT REFRIGERATOR
Whirlpool ET16JMYSF00
Whirlpool ET16JMYSF01
Whirlpool ET16JMYSF02 REFRIGERATORS
Whirlpool ET16JMYSF03 REFRIGERATORS
Whirlpool ET16JMYSG00
Whirlpool ET16JMYSG01
Whirlpool ET16JMYSG02 REFRIGERATORS
  #2 (permalink)
Old 10-21-2008, 10:26 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Generally what happens is: the cap tube has become separated from the suction line. Out of the factory the small tube you see running beside the bigger one is soldered together and the heat off the cap tube(small one) keeps the temperature of the bigger one(suction line) at a level that it wont frost up. Well over the years the solder breaks from corrosion and separates SOoo...what needs done is..... The two refrigerant lines need bonded back together. Remove the top screws holding the condenser to back of frig leaning it up against a wall or something so it doesn't totally fall off and get kinked or broken. Totally strip all the old insulation (using utility knife and one cut vertically all the way down will do it).till it's bare copper, as close to cabinet where it enters freezer section on the outside.if you see the cap tube loosly hanging there and not welded to the suction line Take some black tape and as tight as you can wrap it tie the two together all the way down.then take some plumbers pipe wrap insulation tape and insulate the tubes down to machine compartment area or use some 3/8 armaflexx that is also used for tube insulate in HVAC. Also put some putty back in where the tubes exit outside to keep warm air from going inside freezer.. put it all back together and your done.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frost free refrigerator/freezer frosting over on back wall or bottom freezer bwheeler Refrigerator & Freezer Repair 2 01-31-2011 07:16 AM
Freezer frosting up davidlubb Refrigerator & Freezer Repair 2 11-26-2009 05:44 PM
Frosting up bflartey Refrigerator & Freezer Repair 3 10-29-2009 12:31 PM
Freezer frosting vcathyag Refrigerator & Freezer Repair 1 07-02-2009 07:37 AM
Frosting urbanoanthony Refrigerator & Freezer Repair 1 06-12-2008 10:51 AM
