bclinton
#1 Posted : Tuesday, October 12, 2010 3:57:44 AM(UTC)
bclinton
Help :)
I received my new ice maker. Moved the base from the old one to the new one. All looked good. Its been in connected for 3 days now and hasnt moved. Do you have to turn them on or something? The tines are pointed at 3 O clock or right at me rather than where they normally where. Is there something I have to do to prime the new one? My symptoms with the old one where it would make a batch or two them stop. It wouldnt eject the cubes. The general consensus was that if would do everything except eject the cubes than you pretty much need a new one. The light beam goes out when it should. My only other guess would be a sensor.
Any suggestions?
magician59
#2 Posted : Tuesday, October 12, 2010 5:56:35 AM(UTC)
magician59
Remove the front cover to expose the gear and test ports. Insert a jumper wire between the ports marked, "T" and "H". Then close the flapper to the sensor and hold the door switch in. You should see the gear and the tines slowly move. After it has gone about a third of the way around, remove the jumper. That should start the cycle. [COLOR="Red"]Make sure your jumper is insulated. You're conducting 120VAC through it.[/COLOR]
