ICEMAKER Kenmore ColdSpot
Model 106.54599400
The icemaker is not making ice, no water is coming to the tray. I already replaced the WHOLE icemaker and still not making ice. Still no water. I replaced the pump for the water, and tested the new pump by switching the electrical line from the water dispenser to the icemaker and the water flows, so it is not the pump ( i dont know what it is called, solenoid?)
So, new ICEMAKER, new SOLENOID. Still NO water, what else is wrong
Note that the water line is OK. It will flow water when I hook it up to the water dispenser line.
