I have a glass door beverage air cooler it turns on (the compressor is on, the fan for the coil inside is on and the fan for the coil out in the back is on, both coils are clean.) but it does not get as cold as it use to.
Things I Done to the cooler 1) Clean both coils. 2) cancelled the thermostat and wired direct.
