Great Forum, I have a problem with my icemaker,it was working intermitintly and now has ceasesd. I took the icemaker out and reinstalled it and hear it cycle.I removed the water source and it appears to be fine, no frozen tube in freezer. I read other posts which refer to checking terminals on plugs.R and L test point etc.How do I dertimine which test points are which ? The Icemaker model on this Maytag is IC 11B.I guess I need to test the solinoid in the rear of the frig as well. Thanks for the help and Gene with over 18,000 posts you have gone way beyond helping your fellow man.I hope I can return the favor somehow or somewhere.
