Unconnected ground wire
Model Number: FFC15K1CW0 Brand: Frigidaire Age: 5 - 10 years
I have a Frigidaire commercial freezer. Model # FFC15K1CW0.
Is the power defrost plunger supposed to come out when you lift the top? Or should it stay in unless I pull it out?
I also have an unconnected ground wire. It is close to the thermometer guage/controller & was pulled off when the exterior panel was removed. It is in the midpoint between a ground from further in the metal housing and 1 that is a male/female disconnect F type connector that is attached to the brass housing around the thermostat. The unconnected clip has letters NXW on 1 side & A on the other. I see no where to connect it other than a piece of metal of the exterior panel that is folded in towards the interior just off to the side of the brass housing of the thermometer. Or do I clip it somewhere on the brass housing of the thermometer or somewhere else entirely?
THANKS
Ads By Google
Related Models
