Discuss
Amana TR21VW Evap Fan not getting Power
 in
Refrigerator & Freezer Repair
I have an Amana TR21VW fridge and the evaporator fan is not getting any power. I tried to bypass the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana TR21VW Evap Fan not getting Power
  #1 (permalink)
Old 09-30-2010, 05:49 PM
Junior Member
BrokenFridge is on a distinguished road
Default Amana TR21VW Evap Fan not getting Power
Brand: Amana   Age: More than 10 years
I have an Amana TR21VW fridge and the evaporator fan is not getting any power. I tried to bypass the defrost thermostat with a jumper wire, but the fan is still not getting any power. While I'm doing this testing, the compressor motor is running and so is the condenser fan.
Any ideas on what to try next?
  #2 (permalink)
Old 10-01-2010, 03:33 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Interior cabinet and drain block assy replacement parts for AMANA TR21VW Ref - Top Mount | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag...s/T11021R0.pdf
The defrost thermostat has nothing to do with the fan. It controls the heater shut off.
Since they are running so should the evaporator fan as it is wired in parallel with these components.
All I can think of is that you have a broken wire or bad connection in the wires going to the fan.
Note: I am assuming that you are using a meter to check for AC voltage at the fan.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana refrigerator not working after power surge mellamanjefe Refrigerator & Freezer Repair 0 07-28-2010 07:12 AM
Amana Evap Fan AP4009649 dave.tollison@gmail.com Oven Repair (including Ranges and Cooktops) 1 07-22-2010 07:54 PM
evap fan- cmcan1 Refrigerator & Freezer Repair 1 03-05-2010 02:07 AM
Amana refrig not running (has power) reidjantz Refrigerator & Freezer Repair 3 07-14-2009 05:37 PM
evap fan will not run MMCMUSNRET Refrigerator & Freezer Repair 0 10-10-2008 07:30 PM
