I have followed your directions on how to diagnose a faulty icemake water valve, part # 10524606. Just to be sure that I connect the 2 prong wire connector properly ( it can connect 2 different ways ) , does the white wire connect to the "M" or the "B4" terminal? FYI, the other wire in the connector is tan. Thanks, andylarry
