Refrigidrator keeps popping wall plate surge protector..
If the wall outlet is a ground fault device, your fridg. has developed a electrical fault that it is detecting. They do not recommend using a fridg in a ground fault device as fridgs develop ground faults that are almost impossible to fix and are harmless as long as the grounding system to the fridg outlet is in good shape.
