| » G E refrigerator valve assembly shoots out water |
Model Number: TPX24BP Brand: GE Age: 5 - 10 years
My door water dispenser stopped dispensing. I replaced the water filter and now when the dispenser door switch is depressed, water shoots out the valve assembly at the bottom rear of the refrig. Any ideas what to check or replace?
Quote:
Rick |
Sounds like the tube broke off from the rest of it look around you may see the other end of it most of the tubing coming from the valve is x feet long. when you do see it cut it off square and push in in you have to depress a fitting to get tube out not just by pulling on it
Quote:
The disconnected one may be a separate line to the water dispenser. I'll write back with my search results tonioght. Thanks Rick |
Quote:
Thanks a bunch. That was it. The filler line from the valve to the water dispenser had broken so cleanly (it looked liked it had been made that way), had not been touched, had no reason to break - it broke. I didn't see the line that it was to be hooked up to as that end of the line was still inside the braided insulation tubing that was in perfect condition. Anyway, I pulled out the 4" broken stub still attached to the valve, reconnected to the leftover piece to the water dispenser and viola!! My family has water again. Thanks again, RickJ |
| Display Modes | |
| Water Valve Assembly Problem? | SoCal12thMan | Dishwasher Repair | 0 | 02-20-2010 09:29 PM |
| ge water valve assembly | buffcr39 | Refrigerator & Freezer Repair | 4 | 12-14-2009 07:02 AM |
| ge water valve assembly questions | mharwell01 | Refrigerator & Freezer Repair | 9 | 10-20-2009 02:37 PM |
| Dishwasher water assembly valve | bertnhank | Dishwasher Repair | 1 | 01-06-2009 07:39 PM |
| Replacing water valve assembly on brand new Bosch | NickB | Dishwasher Repair | 2 | 03-28-2008 03:01 AM |
