Discuss
Ice Maker Dispensing Chute Frosted Up & Jams
 in
Refrigerator & Freezer Repair
HELP! I seems like ever since we've had our refridgerator we have been dealing with a problem with our
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Dispensing Chute Frosted Up & Jams
  #1 (permalink)
Old 09-25-2007, 07:21 PM
Roggy Roggy is offline
Junior Member
Roggy is on a distinguished road
Talking Ice Maker Dispensing Chute Frosted Up & Jams
Brand: Kenmore   Age: 1 - 5 years
HELP!
I seems like ever since we've had our refridgerator we have been dealing with a problem with our Ice Maker. The Dispensing Chute continually frosts up and the ice gets jammed up and wont come out. Weekly we have to take the Cube Storage Container out and clean the bottom of it and then clean the Chute. We have replaced the Chute Door but that didn't help. Does anyone have a solution?!?!
  #2 (permalink)
Old 09-28-2007, 02:49 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Make sure the door flapper shuts all the way, if not, take dispenser panel off and look for warped plastic parts or a busted spring. Click on your model # for part removal info.
__________________
  #3 (permalink)
Old 10-03-2007, 03:50 PM
Junior Member
Default
Thanks richappy,
But...I have had a new door installed. The spring is OK. I beleive the door flapper shuts all the way. Any other suggestions??? You say "click" on the model# for part removal info. WHERE's IT AT??? WHERE DO I CLICK???
I had another person tell me to use RTV around all the seams under the Ice Cube Storage Container. (The Container snaps on the door above the Chute) He said to take the section apart that the Container sits on but I can't figure out how to get it apart.
Still Frustrated!
Roggy
  #4 (permalink)
Old 10-08-2007, 06:53 PM
Junior Member
Default
I'm Still Waiting For Someone To Help Me With This Problem. I Thought This Was A Help Forum!?!?
  #5 (permalink)
Old 10-10-2007, 03:22 PM
Junior Member
Default
  #6 (permalink)
Old 10-11-2007, 01:49 AM
Senior Expert
APP Volunteer
Default
WE are waiting for you to post a model #. Most fountain assembles have a removable shelf plate, just pulls out, screws are under the plate.
In my business, I guarantee my service work, did the other guy do this?
__________________
  #7 (permalink)
Old 11-07-2007, 03:57 PM
Junior Member
Angry Still Frustrated!!!
This is a Kenmore Elite.
Model# 106.52603100
As far as the Tech's Guarantee it was over a year ago.
I was so frustated with him I didn't want him to come back.
I tried smearing some RTV around the seams inside the chute area but that hasn't helped either.
Still FRUSTRATED!!!
  #8 (permalink)
Old 11-07-2007, 04:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Roggy
The cause of such problem could be an insufficient temperature in the freezer (it suppose to be about 0 degrees), a bad door sealing or improper door closing.
Check all of them and post the result.
__________________
  #9 (permalink)
Old 12-12-2007, 08:14 AM
gcorbett gcorbett is offline
Junior Member
gcorbett is on a distinguished road
Default
If you are still waiting for help, My GE had the same problem. I removed the cover, over the dispensor door. Removed the 4 screws in the plate, behind the cover. solenoid is on the right side. Sprayed WD 40 on it. Sovled the problem.
  #10 (permalink)
Old 10-15-2008, 10:38 AM
botikiboy botikiboy is offline
Junior Member
botikiboy is on a distinguished road
Default Ice Maker Jamming - A solution
My ice maker was constantly jamming (more times than not) ever since I bought a brand new Frigidaire side by side refrigerator. Eventually, the ice maker motor wore out from fighting the jammed ice. A repairman called me and hit a home run for what caused the ice jams - and he said that he sees this all of the time. The ice crescents (cubes) were too small so they would not eject properly - thus jamming between the raker bar and the plastic fingers. Solution: replace the self piercing saddle valve with a saddle valve that requires a 1/4" predrilled hole. This simply increased the water flow enough to properly fill the ice tray. The hole that the self piercing saddle valve made was so small - probably 1/32" - maybe I didn't pierce deep enough. Anyway, after replacing the motor and saddle valve, I have not had one single ice jam. The water dispenser has much faster flow too.
Also, while working on the ice maker, I discovered that there is a screw adjustment for increasing how much water fills the ice tray - by keeping the micro-switch open longer for the water valve. The adjustment screw is under the plastic cover on the front of the ice maker. This might give you big enough ice to prevent jams but it won't help your water dispenser flow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker chute door won't close ChuckHxxx Refrigerator & Freezer Repair 0 07-18-2009 01:32 PM
Ice dispenser ejecting a combo of crused and cubes. Jams us exit chute bassnman81 Refrigerator & Freezer Repair 1 07-14-2009 02:42 PM
Kenmore Ice Maker Chute jusride7 Refrigerator & Freezer Repair 0 12-16-2008 07:04 PM
Ice maker chute door won't allow ice to fall thru majorwest Refrigerator & Freezer Repair 2 11-17-2008 08:00 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
